Question about Keurig Coffee Makers & Espresso Machines
Keurig spits water and grounds out of the top hole in the cup. Is there supposed to be a rubber seal on the top needle?
  • 460 Answers
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
Posted on Nov 12, 2009
  • 60 Answers
SOURCE: I have had my Keurig B60 coffee maker for over a
Valve is not bad that is not the issue you need to contact keurig to help you Call Keurig 1800 Cup Brew
Posted on Mar 23, 2010
cmccune04
  • 213 Answers
SOURCE: lost orange seal for keurig b50
Here is the part your looking for: http://iwantsweetdeals.com/Keurig-B30-B40-B50-B60-B66-B70-B77-Replacement-foam-Needle-seal-P1227320.aspx
Hope this helps you
Posted on May 26, 2010
  • 40 Answers
SOURCE: the keurig spits water into
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
Keurig K10 water spills out top and sides while brewing
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
Mar 22, 2014 | Keurig Coffee Makers & Espresso Machines
When i use my reusable k cup, water comes out all over
Use the $15 reusable Kcup with a rubber seal ring. If the lid is not down and sealed it will over flow with grinds. Press down firmly after filling with grinds. Also, clean tubes Top/Bottom with a paper clip to free them from debris that clog the tubes. Use distilled water also.
Jan 07, 2014 | Keurig Coffee Makers & Espresso Machines
I have a K10 mini cup keurig brewer. It worked fine until this morning. When I try to brew a cup, it comes out the top. It does with this with or without a k-cup in. I tried to clean out the needles...
First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 27, 2013 | Keurig Coffee Makers & Espresso Machines
Keurig leaking from bottom
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
OR:
Oct 07, 2013 | Coffee Makers & Espresso Machines
Keurig recalls
That means you have a plugged lower port in the basket and it needs cleaning.
Feb 12, 2012 | Keurig B31
Keurig B31 one cupcoffee maker users mannual
Keurig calls the B31 the Mini Plus Brewer. The manual is available from the Keurig Customer Service site: http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help . The direct link to the English version of the Use and Care Manual is http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/B31%20UCG%20ENG_FRE.ashx .
I hope this helps.
Nov 08, 2011 | Keurig B60 Coffee Maker
My keurig B40 coffee maker just pure out water hardly any coffee. It makes it taste like a weak coffee even when it's should be strong. It was blocked and we try vinegar but that wasn't the problem. We...
Look at the top needle, there should be a rubber like seal that sits around its base. This seals the needle so all the water with pressure goes the the cup. If the seals not there, it can't build the water pressure necessary to go through the coffee inside the cup, thus coming out around needle and out around cup, making it mostly water in your coffe cup.
Mar 03, 2011 | Keurig Elite B40 Coffee Maker
Keurig b31 brewer is not bewing 2 week old machine
Important discovery I wanted to share.
My B31 Kuerig worked great for over a year, then suddenly seemed unable to spit out any coffee or even water when no coffee pack was loaded. Descaling did nothing to fix ... only a drop or two of water (or vinegar) could flow out the machine.
I was able to fix it by clearing grounds stuck in the holes of the TOP needle, NOT the needle opening in the funnel for the bottom of the cups.
The instruction manual for the B31 does not tell you to clean the top needle ... it just says how to clean the funnel and the bottom (exit) needle ... but the Kuerig video on YouTube does explain where to find the top needle and how to clear it of a jam from corrosion or coffee grounds.
http://www.youtube.com/watch?v=C4i7pMWbRvA
Be careful ... the top needle is sharp, and it is hard to spot the tiny slots in it.
Using a paperclip, I was able to push up and clear some grounds that were blacking water from flowing freely. These grounds then came out with my next cycle of water.
To see the upper needle, look up into the top of the machine after you open it. There are also two screws you can take out to see the top tube of water flow down to the coffee cup. That is where I was able to spot some grounds that came lose after I used a paperclip to clear.
I was ready to trash my machine ... now it is good as new. Good luck!
Jan 11, 2011 | Keurig B60 Coffee Maker
Special Edition B60 Coffee Maker: Coffee grounds coming up through the k cup???...
make sure the k-cup is being punctured at the bottom... If the answer is YES... then take the K-cup holder out of the Keurig unit... verify you can put a paperclip into the needle of that piece from the inside of the shell and it comes out the bottom
that shell is actually 2 pieces and unsnaps... making it earier for you to check... once we know there is no obstruction in the bottom needle, then we need to make sure the rubber gasket in the top arm is ok... didnt come off..
the top needle that punches a hole in the k-cup, has a round rubber seal around it..
If it's not there, then it got stuck on the top of a k-cup, and you need to search the garbage for it...
in summary
clogged bottom needle
missing rubber top seal
If the rubber seal is there... hmm. while your making coffee next time....press down on the top arm... just enough to see if the ground stop... id that's the case, then we need to step back and think if we are dealing with either a bad seal, or a fatigued top arm..
My hunch is a bad seal... and possibly try to attempt to reseat it back into the arm... it cound be smashed in and needs to be coaxed back out..
May 06, 2010 | Keurig Special Edition B60 Coffee Maker
Coffee grounds in the cup
since you said usually... I suspect the rubber seal that surrounds the top needle is not seating well...
you can verify this by making a beverage with a k-cup and, just before the water starts, add a little hand pressure to the K-cup arm pushing down a little bit... not hard...
If it consistently makes a good beverage, then we focus our attention to that piece of the brewer...
when the consistency of the water changes, it tells me to look for leaks or unusual percolation of water...
you can verify the K-cup holder is ok... but another way to simulate the hand pressure is to put a shim of some sorts under the lip of the k-cup... like the thickness of a couple sheets of paper under the rim... not the actual k-cup... but the k-cup holder... raising it up a smidge is the same as the slight hand pressure...
I would look to see if the rubber seal has come loose around the top needle....
May 04, 2010 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
