Question about Refrigerators
The water filter light will not go off and the tumbledryer works for a little bit then it stops
3 Suggested Answers
  • 129 Answers
SOURCE: Whirlpool Cabrio stopped working mid cycle and
CLEAN WATER PUMP
Posted on Jan 31, 2010
SOURCE: TCE 7227 W tumbledryer waterconductivity needing regular restting
Carolsquires, I have the same problem with 7227, did you get a solution?
Trevor
Posted on May 31, 2010
MY TUMBLEDRYER HAS JUST STOPPED WORKING SUDDENLY, POWER STILL ON BUT NOTHING HAPPENING. HAVE CHECKED AND CLEANED ALL FILTERS
belts break . , heating elements burn out . repairmen are the best choice to find out what is wrong .
Feb 10, 2016 | Dryers
Whirlpool awm 6120. does not work and light are blinking.
Hard to know without more information, have you checked pump filter in flap at bottom of machine or tilt forward if you get a little bit of water you have a leak inside and a sensor will stop machine, if it will run after tilting machine that would confirm your problem.
Jun 23, 2013 | Washing Machines
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
May 13, 2011 | Whirlpool 4396841 Whirlpool Refrigerator...
Hi, I have an ASKO D3250 dishwasher and it keeps stopping during the wash cycle and flashing the heavy pots and pots symbol simultaneously. I tried cleaning the filter basket and found a little plastic...
The part is a cap for the drain pump. You can put it back into position by removing the filters and placing it to the left of where the circular filter would be positioned. The part goes in with the part numbers on the bottom facing down. When positioned it should not interfere with the threads for the circular filter. You may have to scoop out the water in the bottom, to have a better look at how it is positioned. It is always normal to have a little bit of water in the bottom filter area (below the silver screen filter).
Oct 18, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Filter rattleing in front compatment
Assuming that by "filter" you mean the bit behind that little door at the bottom on the front of the machine........
The other thing that's in there is the workings of the drain pump. It sounds to me as if something hard has got in there and is stopping the pump from turning properly.
Turn the power off before you start.
Once you've got all the water out, all you'll need to do is to open up, remove the obstruction and (if it's what I expect it is) buy yourself a drink with it. (There is a big round plug behing the little door. Give it a quarter turn and it will pull out. On some machines, you may have to loosen a small locking screw before the front of the plug will turn)
The tricky part of this is getting the water out when the pump isn't working. The best approach is to pull the machine away from the wall. Put a basin on the floor, then remove the drain hose from the standpipe it plugs into and allow the machine to empty by gravity into the basin. When the basin is about half full, lift the hose up to stop the flow and empty the basin before starting again. This way, you can get the majority of the water out of the machine.
There is always going to be a little bit of water left. The safest way to deal with this is to put cloths down to catch what spills, slide a baking tray under the corner of the machine, and crack open the pump/filter cover (closing it again to allow you to empty the baking tray) - repeating until no more water comes out.
An alternative approach to this last bit is to tip the machine backwards, physically remove the drain pump from the machine (while still connected to all the hoses) and then suspend it over the basin while opening it up. If you know what you're doing, this is much quicker and cleaner than the baking tray approach - but you have to be really careful not to get the electrical bits of the pump wet and not to let the machine topple over onto anybody.
A.
May 02, 2010 | Zanussi FJS1225W Front Load Washer
Trevor
Feb 17, 2010 | Zanussi Dryers
Candy CIV60 Tumbledryer - Reverse Action not working?
this could be something caught in the blower housing fan blade but what it sounds like is the motor is going into thermal overload (overheating)
Sep 01, 2009 | Candy CDC266 Dryer
Suddenly stopped working
remove bucket, look under for the bucket overflow switch, try tugging it a bit, may have gotten stuck when you pulled out the bucket
Jul 24, 2009 | Goldstar DH304 Dehumidifier
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
