Question about Drills
How do I change the bit on my porter-cable 18v drill? Where/how do I line up the black dial with the silver dial to release the bit??
  • 4,498 Answers
I just looked at some illustrations on ebay of Porter-cable 18 volt drills and they appear to be fairly standard cordless drill/drivers fitted with fairly standard keyless chucks that you get hold of with both hands and twist in opposite directions like you are giving it a Chinese burn. The part of the chuck nearest the bit twists anti-clockwise to loosen.
If you have an SDS drill for heavier duty jobs the chuck is semi-automatic in the drill bit just needs pushing into the chuck and clicks into place but the outer part of the chuck is pulled back in order to release the bit.
Posted on May 07, 2017
Fuse for Porter Cable PCMVC T2
It is not q cost effective repair. I understand your wanting to repair it. I have disposed of several 18V tools because of the cost of replacement batteries. I found it a better solution to watch for sale and buy a new tool with 2 batteries and charger. Good Luck.
Sep 25, 2017 | Porter Cable Drills
Is there 2 type of battery chargers for ryobi one+ and lithium 18v one +
I just went through this with Porter Cable 18V but I can't say it is the same for Ryobi. On the PC, all 18V batteries are interchangable on the tools, but the charging needs are different. A dedicated NiCad charger can't shouldn't be used for liOn but the later chargers will work for either battery.
Ryobi offers an 18V upgrade:
RYOBI Tools
Jan 02, 2015 | Ryobi Drills
Husband is out of town so how do you change the drill bit on the porter cable keyless chuck drill?
Switch drill to reverse, grab drill head tight, do not grab bit, pull trigger, chuck will open, switch to forward center new bit hold head tight pull trigger. Make sure bit stays in center, Let me know if this helps.
Aug 21, 2011 | Porter Cable Garden
How do you release the bits to change sizes
It is a keyless chuck. You should be able to grab the main body of the chuck and turn it to the left to release the bit. You can also hold the main body of the chuck and run the tool slowly in reverse whcih will also release the bit.
Jul 10, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I just bought my 18V Porter Cable and the charger light comes on for 1 sec. then goes off, wont charge
I have been having problems with this charger also.
I have gone through 4 of them, I just posted here, & my son is attending RPI, & is going to research it, if I find any info I will relay it to you
Good luck
Steve C.
Jan 04, 2011 | Porter Cable 19.2V Drill Kit
How do I remove a stuck bit from the chuck?
put the drill in a vice. then use the chuck key  and a hammer to release the bit.
 if necessary use wd40 spray to free up chuck.
Jan 24, 2010 | Black & Decker 18V Cordless Drill/Driver
Brand new drill won't charge - never battery
You have the right to return the second unit for a refund or credit on another brand
Jul 22, 2009 | Porter Cable-Cable PCL180DK-2 18-Volt...
How do you change the drill bit for a Ryobi?
My husband explained this, via phone ..... made it simple....... grab the silver ring area beneath the black top area where the drill bit is located. Hold the silver area firmly, while you twist the black top. You will see the release, then remove drill bit. Laymen's terms, but it worked!!
Mar 16, 2009 | Ryobi 18v Variable Speed Impact Driver...
Drills Logo
168 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
