Question about Garden
My chainsaw won't cut. It's tight enough and isn't dull. Can you tell me why?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Is there oil for lubrication?
Is the chain really sharp. It will have to be filed regularly or exchanged. When I find that the saw does not cut well I know it is time to sharpen the chain or get a new one.
Posted on May 07, 2017
As the chain stretches for McCulloch chainsaw Titan 7
a couple things will cause a chain to stretch running it to tight running low on oil a dull chain over heats it
Sep 20, 2012 | Garden
I have purchased Poulon pro 42cc 18 inch chainsaw. I am extremely satisfied with my chainsaw until now. I have only owned it for about two months. I only used it maybe 10 times for easy tasks. my chainsaw...
The chain needs sharpened or replaced. You can purchase the tools from any hardware store, and sharpen the chain yourself in about 15 minutes. Don't worry, your saw is just fine!
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is wrong if a chainsaw is running good but when you put it on a load it bogs down and want cut
Check the air filter, and make sure the chain tention isn't too tight. Also make sure the bar lock isn't in the locked position. If thats not the problem, remove the access cover to the drive pulley, and check for a jam... Hope it helps!
Sep 24, 2011 | Husqvarna Garden
I have an older McCulloch chain saw- Pro Mac 610. When using the saw the chain will get very tight. If I adjust the chain to the proper tension, make a couple of cuts the chain loosens and must be...
The main reason for a chain to tighten is because it is not getting enough oil to the bar, or too thin an oil is being used, you should see a good spray of oil off the end of the bar when held against a tree stump, if not try adjusting the flow if it has an adjuster.
Apr 01, 2011 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
Poor cutting and over heating. Have cleaned it and have enough oil and checked chain is on correctly.
It does not take much to take the cutting edge off a chain saw. A few accidental excursions into sand or dirty logs quickly dull the teeth. Check that your chain cutting teeth are sharp, blunt teeth will overload the motor and cause it to run hot. Chains can be sharpened several times before needing replacement and can be done DIY or taken to specialist sharpeners.
Mar 18, 2011 | Bosch Garden
Chainsaw not cutting straight
The problem is that the chain is dull on one side...you hit something on one side of the chain and dulled the teeth on that side and now it tries to cut in a circle....
Either get a new chain...sharpen the chain your self... this is tricky if you have never done it before...or have a pro sharpen the chain...
heatman101
Aug 28, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain wont stay tight
Is the chain being properly oiled? Make sure the cover fasteners are tight after adjustment. If the chain is dull or is improperly sharpened, it will heat badly causing the chain to become loose. Adjust the chain (cover fasteners finger tight) so that the chain just comes up to the lower bar, but not so tight that you can't pull the chain by hand. Make sure the teeth cut toward you on the bottom run. Run the engine at speed with the bar tip near some cardboard for a few moments, it should throw off a thin line of oil onto the board. Hope some of this helps!
Jun 23, 2010 | Poulan Pro Chain Saw 46cc 20"
I have a Husqvarna 55 and it will cut but not great. The chain will stop and the engine will bog even on full throttle. Is it the clutch?
Is your chain sharp? Sometimes you hit stuff in wood without realizing it and it dulls your chain, dirt, nails, trash, it's all bad for the chain. If you aren't getting enough oil on your chain while cutting it will also shorten the life of your chain dramatically.
Apr 26, 2010 | Garden
Chain smoking while cutting,hard cutting,and pull string hard to pull new saw.
too much oil in the fuel, or set screws are not mixing air fuel properly. have the set screws looked at, and listen for a bearing to be gone, there are two un related issues here.
Dec 15, 2009 | Poulan Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
