Intermatic PE953 Spa Remote Display stopped working.
PE953 Remote - ZWave connected to Spa Controller. Screen now displays white light with no text, though text has popped up (or at least was popping up) occasionally for a short couple of seconds. Remote does operate spa filter speed, light, etc but have to guess screen it is on to turn that function on or off.
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Posted on Oct 19, 2008
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
  • 323 Answers
SOURCE: The blower on my spa will not turn on
If you've made no changes to the wiring from when it worked correctly, then it can only be the switch. Get a new one, switch off the breakers, and wire it in according to the instruction that come with it.
Posted on May 28, 2009
  • 12744 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Posted on Nov 04, 2009
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ... > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ... > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
P1353ME Intermatic Pool Timer starts and then stops
sounds like you are working with 220 2 blue are two hots across the two you should get 220 volts each of the greens and green should only give you 120 volts make sure unit can be wired 220 volts
Jul 05, 2015 | Intermatic P1353ME Timer, 3-Circuit Pool &...
I have Aqualink RS6. Screen is lit, but no display. Is they some thing I can check?
Check to see if all 4 wires are connected inside the controller (your inside wall unit) and also at the power center outside. After removing the cover outside you will see a red 4 terminal strip (4 wires) above the buttons. Above the buttons is low voltage, below the buttons where the relays are is high voltage, be careful.
Your inside controller (cover pops off from below) has the same red terminal strip that hold the other ends of those same wires. If you have a later model it may use a telephone type connection.
If it all looks good call a pool tech who should have a portable controller, he can plug in outside to see what happens. Good luck with it.
Jan 28, 2013 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
We have an NEC Plasma 60xp10 tv and NEC RU-M111 remote controller. we accidentally hit the pip button and now we can't get it to turn off. a black small box randomly pots on and off.
The black box is likely in the CC area labeled TEXT and can come from the set or a box connected for signal.
The other issue sounds like PIP or picture in picture is engaged.
Both issues may require the original remote to turn them off.
Dec 15, 2012 | NEC PlasmaSync 60XP10 60 in. TV
Display Light on Jandy wall remote
check at aqualink take off front panel see if 4 pin red connector is plugged in if ok see if wire is cut if ok need new display board or make a cheater cord and plug in at aqualink if ok need new wire to controller if no display replace
Mar 15, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have an intermatic RC3621RT 5 circuit timer with remote controls for the spa. I'd like to upgrade, but I cant find a cross reference for a new box that would be the same. Can you help?
Following pdf file shows Intermatic pool and spa controls and Spa.ashx.pdf
PE40000 series has remote control and 5 SPST circuits (3 timed with timer and 2 on-demand with remote control). Can be wired for both 120V and 240V circuits, so pump can be 240 and lights 120, or both 120.
The new timers are electronic
Intermatic pool and spa website with contact-us information & manuals:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Intermatic Hardware & Accessories
I have 2 black wires at home one that usually connects to ON side of the switch and other black connects that OFF side (bottom) of the switch.. I'm trying to use Intermatics Touch CA3000 switch - but...
One of the blacks is a hot that connects to the black wire on the switch. The other black wire is the switch leg (to the light) that connects to the blue wire. The yellow wire on the switch is not connected in a single pole application. If you don't know which black wire is hot you'll need a volt tester.
The CA3000 is then controlled with the CA5500BR Handheld Remote with Smart Base.
Jan 15, 2011 | Intermatic CA3000 InTouch Wireless...
White screen can't see the display text
maybe there is a problem in touch screen display check the small board connect to lcd display
Nov 27, 2010 | Canon NP 6551 Black and White Copier
On screen notice says to reconnect the controller game paused
it might be the battery pack try to hold the battery pack tighter on the controller then try turning it on
Aug 01, 2010 | Microsoft Xbox 360 Console
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
