Question about The Computers & Internet
Hi. I have a Back and Decker model BPRR1200 router. I want to know how to replace the bearings on this router? Kind regards Louw
ASKO DRYER T700, DRUM IS MAKING BANGING SOUND AS IT SPINS.
Hi.
The loud banging noise in the spin part of the cycle is usually caused by bad drum bearings. The repair is carried replacing the bearing at the back of the drum. Such kind of replacement is carried disassembling most of the appliance to reach the back of the tub. If you have not done similar repairs before it may be better to call a technician ringing the Asko support number listed on the owners manual.
Regards.
Ginko
Sep 09, 2011 | Dryers
I have a problem with a wireless router wgr614. Some kind of fluid was leaking from him, and he stoped working. I don't know if some kondensator went wrong, but the fluid does not make any sence. please...
This is because the router has gone bad. turn off your router first and unplug all the cables connected to it.Then contact your Netgear and get your router replaced if you have the warranty period.
With Regards, Prema.
Feb 18, 2011 | NetGear WGR614 Wireless Router
Wheel bearing tork bad bearing needs replacing
Welcome to FixYa.com Year make and model please. You need to know how to change the bearing?
Thank you for Using FixYa.com Kind Regards, Lee Your FixYa Expert and Master Technician
Feb 11, 2011 | Chevrolet Chevy Cars & Trucks
Hi i would like the wep key to my router please..
Hello
OK, firstly, your WEP code the a personal security code of the router, which secures your network.
This code is usually on the back, or bottom of the router. If you have personalised the router, you will need to log into the router and change the SSID name of the router. After you have changed the SSID of the router, you will be able to change the WEP code.
Please do not hesitate to let me know if you need any further assistance.
Kind regards
Lock123
Dec 09, 2010 | Netopia 2247NWG-VGx Wireless Router...
BENZ C180 2000
i think your car is not recognising your key.Sometimes the battery runs out and need replacing and if you are not lucky then you may need to contact a dealer to have the key reprogrammed..this will cost you..
Jun 17, 2009 | 2000 Mercedes-Benz C-Class
Help me please
I think Not.
There are ADSL wireless routers however.
I guess your purpose is to make your ADSL modem available wirelessly, you can connect the
modem via lan line to the wireless and use that as a router.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Craftsman lawn mower
Hi judycdenn
You can get replacement wheels from most decent hardware stores, either with ball race bearings, or just plain old plastic bushes. they don't cost much, I would take in my old wheel to get one that fits.
But before you go buying spares for the mower... you should read this
regards
robotek
Apr 28, 2008 | Black & Decker 19" Electric Lawnhog...
I came back from vacation and my wireless network is showing up as security encripted. I've never set a security code how do I reset?
Two way to remove security encryption:
1. disable in your wireless setup (Either the WEP or WPA);
2. full reset the router. Press the small recessed button for more than 10 seconds. (However this will also remove and and all settings of the router including the WAN)
For simplicity, perhaps option ! would be the safest for your requirement.
If for some reason the above does not work for you, pls post back brand and model of your router.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 28, 2008 | Computers & Internet
Router Configuration in "Wireless Client" Mode
Hi, If I understand you right, what you want to do is to make the DI-524 as a repeater, i.e. receive from the "external wireless access point" and re-broadcast to your "small home wireless LAN". Unfortunately, no. D-Link made it a point not to enable repeater mode in the DI-524 model (firmware has no support for wireless distribution service). Other than your old DWL-900AP+, one other model they have that can do this is the DWL-G710 but only in WiFi and not in the Ethernet port. On some other brands of similar feature models, the original manufacturer's firmware may be replaced with an open source firmware with more features enabled. An example is the LinkSys' WRT54G and the replacement firmwares by Sveasoft and another named DD-WRT. Hope this be of some information to you. Post back should you require additional information. Good luck and kind regards.
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
