Question about Samsung Digimax S630 Digital Camera
Card lock.? I have a Samsung S630 and everytime i try to take a picture a black screen comes up with card lock. it is reonably new too. It is not coming up due to the slidey thing on the actual memory card. I have tryed to unlock it by formatting it but it says again card lock. What can i do?
  • 54 Answers
Friend dont worry it so simple
Insert u r card into card reader and then change its format
Up to
Fat or Fat 32 Into NTFS and format it if it is formated then it will be ok
Posted on Jul 25, 2009
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get...
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Oct 20, 2010 | Samsung S630 Digital Camera
When I try to take a picture, it displays CARD
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 04, 2010 | Samsung Cameras
Screen says card locked when tryin to take a picture
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 25, 2009 | Samsung Digimax S630 Digital Camera
Card lock
Dear geogie:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
Jun 09, 2008 | Samsung S630 Digital Camera
Samsung digital camera S750
there will be a little slide lock on the side of your memory card you just need to unlock it
May 31, 2008 | Samsung Digimax S630 Digital Camera
My memorycard is locked how do i open it
hi debbie;
have you tried formatting your memory card from your camera menu? i havent seen a memory card without lock pin but you may try my advice. :)
May 18, 2008 | Samsung Digimax S630 Digital Camera
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Card Locked?
There is a switch in the memory card, you just have to slide it upward.
If you are using a new memory card, format it first.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2
- Select Format
- Select Yes
Nov 13, 2007 | Samsung Digimax S630 Digital Camera
Sandisk is On card lock???
The card probably needs to be formatted for your camera but that will erase the pictures already on the card. Far as I know each card must be formatted to the camera for which it is to be used. Use the menu button to find format. (Last icon, "wrench2", format is toward the bottom of the list. Remember you will lose the pictures already on the card, so save them first.
Aug 02, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
151 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
