Channel 117 is not available. The satalite info says that there is no signal. flashes 89 on the left and 100% on right then goes off. all other channels working fine
SOURCE: Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Posted on Jan 23, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
SOURCE: Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Posted on Jun 24, 2009
  • 4234 Answers
SOURCE: i have a peavey cs-800x that i used to DJ
The CS800 designs have not changed mucch in the last 20+ years. There is a resistor inside that can fail that can cause this symptom. If you have not worked on these before, I'd suggest that you have this serviced. As it stands the parts cost should be in the $20 range. If the outputs have finally failed, the parts cost will go up significantly. WIthout taking measurements inside the unit, I can't say specifically what is wrong.
Hope this helps,
Dan
Posted on Aug 20, 2009
dunnbiker
  • 8546 Answers
SOURCE: Left Channel does not work
Sort of sounds like there's a PC in the mix.
Can you swap the left and right speakers to isolate the speaker from the source as the problem?
Have you tried switching the various plugs around to isolate if anything comes out to the Left Channel, ever or if any other speaker plugged in as the Left works at all? Turn the volume down and bring it up slowly at first because if you send Subwoofer programming to a speaker not designed for it you may damage it.
If nothing works when plugged in as the Left speaker, maybe the sound card is the problem. Resubmit a question with the source or the PC as the problem
Posted on Nov 30, 2009
Need to wire up a factory radio plug for 2003 chevy tahoe z71 with bose premium system. need to know what wire gose in what pin in the plug. SOMEONE PLEASE HELP ME!!! PLEASE!!!
Connector Part Information
12110088 (Except UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRY) (Except UQ7 w/o Y91)
15428074 (UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRN) (UQ7 w/o Y91)
Pin
Wire Color
Circuit No.
Function
A1
ORN
1044
Radio Class 2 Serial Data
A2
Not Used
A3
PPL
493
Rear Seat Audio Enable Signal (UQ7 w/o Y91)
A4
RED
1486
FM Composite Signal (UQ7 w/ Y91)
A5-A7
Not Used
A8
TAN
201
Left Front Speaker Output (+) (UQ3/UQ5)
A8
TAN
511
Left Front Low Level Audio Signal (+) (UQ7)
A9
GRY
118
Left Front Speaker Output (-) (UQ3/UQ5)
A9
DK GRN
1947
Left Front Low Level Audio Signal (-) (UQ7)
A10
LT BLU
115
Right Rear Speaker Output (-) (UQ3/UQ5)
A10
BLK
1946
Right Rear Low Level Audio Signal (-) (UQ7)
A11
DK BLU
46
Right Rear Speaker Output (+) (UQ3/UQ5)
A11
DK BLU
546
Right Rear Low Level Audio Signal (+) (UQ7)
A12
BLK/WHT
1851
Ground
B1
ORN
340
Battery Positive Voltage
B2
Not Used
B3
PNK
314
Radio On Signal (UQ7 w/o Y91)
B3
DK GRN
145
Antenna Enable Signal (UQ7 w/ Y91)
B4
BRN/WHT
230
Instrument Panel Lamps Dimming Control (w/ Y91)
B5
BLK/WHT
1851
Ground (w/ Y91)
B6
GRY/BLK
2334
Radio Mute (UQ7 w/o Y91)
B7
Not Used
B8
BRN
199
Left Rear Speaker Output (+) (UQ3/UQ5)
B8
BRN
599
Left Rear Low Level Audio Signal (+) (UQ7)
B9
YEL
116
Left Rear Speaker Output (-) (UQ3/UQ5)
B9
DK GRN/
WHT
1547
Left Rear Low Level Audio Signal (-) (UQ7)
B10
DK GRN
200
Right Front Speaker Output (+) (UQ3/UQ5)
B10
ORN/BLK
1546
Right Front Low Level Audio Signal (-) (UQ7)
B11
LT GRN
117
Right Front Speaker Output (-) (UQ3/UQ5)
B11
LT GRN
512
Right Front Low Level Audio Signal (+) (UQ7)
B12
Not Used
Oct 20, 2015 | Cars & Trucks
Very week sound
Definitely need more info - such as type of amplifier or receiver, how many speakers you are running, whether the subwoofer is powered or not.
As a simple test procedure: Disconnect all speakers and plug in a pair of headphones. Get a strong audio signal? Good, move on. No signal or week signal, you have an amplifier issue before the audio even gets to the speakers.
Next: Disconnect all speakers, turn the volume down, and connect one speaker to the left output channel. Slowly increase the volume. If that works, do the same on the right channel. Everything OK? You're putting out enough gain on both channels. Sometimes one channel goes bad. You can still listen to your sound in mono moder, or drive two speakers from the single working output. Not stereo, but dual mono. Move on.
Connect left and right speakers but not the subwoofer. Repeat the test. Whatever is left is probably the problem. If the subwoofer is powered, check the power supply or incoming voltage. If the other speakers are driven off the subwoofer or powered from there, that's likely the problem.
Jul 31, 2015 | Audio Players & Recorders
1998 buick regal stereo what are the wire color codes
showgif.do?image=73222
12110115
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
Dec 20, 2014 | 1998 Buick Regal
Power button is flashing and no signal
Flashing of power button is fault indications. To know more, visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 800 posts to different brand TVs now.
Sep 22, 2012 | Sylvania Televison & Video
Just purchased panansonic tc-p42g25 plasm. message on screen (channel not available no signal).
U tries cable or satalite boxes unplug,replug it back like an hour later?Now,the satalite or cable boxes should resetting itself back to the factory setting and upgrading it softwwares.The tv should have a signal now.If not,it is the cable or satalite boxes fault.Call the cable or satalite companies,request for a new box.
Nov 27, 2010 | Panasonic Televison & Video
I pressed the cahannel up and down button on my panasonicTv and I changed the input signal. It is a black screen and it says no channel available no signal. How do I fix this?
Tries a better antena like a digital antena or a roof antena for the free air tv signal.Rescan the channels.
If cable,satalite or telicom signals unplug replug the reciever box for reboot to upgrade.Make sure ur tv in cable setting,rescan for for dhannels.
Nov 07, 2009 | Televison & Video
Digital picture freezes for split second every now and again
U have Cable,Satalite,or Teleticom Siginals ur incoming signals 99.999%.Digital antena about 95%.Roof antena about 90%.Indoor Analog antena about 89%.Yes the signals is varies u will have freezes,not ur tv
Oct 15, 2009 | Televison & Video
Snowy pictures
The dish left behind it just a shell to recive signal,no signal,must pay to recieve channels,like cable or satalite signals.Tries,get new cable,to get signal or must buy a digital antena,or roof antena to get new digital signals.
Oct 10, 2009 | LG 42LC2D 42 in. LCD HDTV
The one for all remote control model urc-7562 funtion on the menu doesnt work what could be the problem?
Hello Stephendo394:
Here are some advanced codes that were found on Remote Central.com web site.
003 Menu
004 Timer Recording
010 Timer Recording
024 Shutdown
026 Shutdown
036 Skip 30 sec
039 Next Page in Menu/Next Track in Play mode
041 Previous Page in Menu/Previous Track in Play mode
043 Time Slip
053 Record
055 Play
061 Right
065 AV
070 NTSC/PAL
076 Language Right
080 Language Left
084 Source
091 Source = SD
100 Playlist View
101 AV
105 Tape Speed
106 Advanced
116 5
117 1
118 7
119 3
120 6
121 2
122 8
123 4
124 Setup
127 Picture Info
140 ?
146 Record
148 Channel Down
152 Channel Up
162 HDD Management
164 Delete
178 Record Flexi-Mode
179 Source = DVD
180 Rewind
181 Returns to Menu
182 Pause/Play
183 Rewind
184 Forward
185 DVD In/Out
187 Forward
189 Context Menu
191 Enter
192 Up
193 Return
194 Left
197 Guide
198 Info
215 ?
219 ?
229 Create Chapter
230 ?
234 Display
245 9
249 0
Aug 20, 2008 | Televison & Video
Turning signals have quit flashing. bought a elecronic flasher but not a clue where it goes
I had to use a pair of vise grips on the receiver to get a good enough grip and pull the plug like heck. There is another flasher for the emergency flashers located to the right side of the glove box (glove box has to be removed) on the far side of the alarm box for "keys left in ignition"
Jul 25, 2008 | 1989 Oldsmobile Cutlass Ciera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
