Question about RCA Televison & Video
My RCA TV (46LA45RQ)has lost its red color channel. Picture washed out. Red adjustment maxes out at 50. ??
  • 556 Answers
SOURCE: Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Posted on Sep 10, 2007
  • 8 Answers
SOURCE: Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Posted on Dec 31, 2007
  • 10594 Answers
If your TV is rear-projection system, it got problem in convergence board, may be few bad-solder connections.
Posted on May 30, 2008
SOURCE: rca tv r52wh73 the picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Posted on Oct 17, 2008
  • 8 Answers
SOURCE: 5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Posted on Jan 30, 2009
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
Dec 21, 2010 | RCA G36705 36" TV
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
You can see some more examples and find a fix using this link on Fixya
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
I have an RCA 50 inch projection tv that all of a sudden looks like the picture is warped on the screen.I can not make screen adjustments with the remote to solve it.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Jul 13, 2009 | Toshiba 50H72 50" Rear Projection...
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Picture color
Sep 09, 2007 | JVC AV-32F702 32" TV
RCA CTC203 no red colour
Did you change the resistor by yourself? I am not sure if your TV has manual adjust on the back of the TV that you can adjust. Some times turning the TV Off and unplug it from the wall helps because it resets the TV. Check your Back ground color and see what is the dominating color. Blue, Green or Red. If this doesn't work please call a professional to look at it.
Jun 18, 2007 | RCA F27649 27" TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
