Question about Lands Phones
How to set year month date and time in beetel M59 telephone
SOURCE: date and month
There are three positions when you unscrew the crown stem. One does the day, one does the date and one does the time. You can also advance the date by rotating the crown stem and advance the time for 24 hours, as if a day passed. That takes a lot longer.
Posted on Jan 13, 2008
  • 13433 Answers
SOURCE: unable set time & date
Here is the user manual
http://www.sonyericsson.com/cws/download/1/265/274/1193035322/Z320i__UG_R1a_EN.pdf
Page 29 for instructions
Posted on Jun 18, 2008
SOURCE: Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Posted on Feb 17, 2009
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Posted on Mar 06, 2009
  • 336 Answers
SOURCE: How do you set the timeand date on a toshiba dkt
Please try this..
  1. From main console phone (lowest extension number i.e. x100) pick up handset and dial following codes:
  2. For Date: 651 YYMMDD Redial ----(YY=year, MM=month, DD=day)
  3. For Time: 652 HHMMSS Redial ----(HH=hours in 24hr clock, MM=minutes, SS=seconds)
  4. For Day of Week: 653 X Redial ----(X=day of week 1=sunday, 2=monday....etc.)
If won't work, try this
From Extension port 00 (usualy station 200)
  1. Lift Handset Dial #652
  2. Enter Correct Time HH MM SS
  3. Press Redial
  4. Replace Handset
Regards,
Jeep Brainy
Posted on Aug 10, 2009
Beetel m59 user manual
how to do call forwarding in beetel df5300
Mar 12, 2016 | Lands Phones
Tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 | Lands Phones
I have installed an brand new bizhub c 364 machine, now it gives me security lines either blue or red , can anyone help me in solving the problem ,thankyou
Install was done incorrectly,
CAUSE: Initial settings did not take when programmed.
SOLUTION: Time and date, telephone and ADF serial numbers need to be reentered:
1. Sub-power ON g Utility/Counter g Machine Admin settings g System settings g Date and time setting g (Enter year/month/day/time) g OK g Exit g Power OFF sub-power switch.
2. Enter Service Mode g System settings g Setup date input g (Enter year/month/day) g OK.
CAUTION: DO NOT POWER OFF. Leave machine in Service Mode.
3. In the Service Mode g System settings g Telephone setting g (Enter 16-digit number) g OK. Repeat for the fax number. Set to all 9s if there is no fax number.
4. In the Service Mode g System settings g M/C serial number setting g touch ADF g (Enter ADF serial number) g OK g Power OFF sub-switch.
5. Power ON sub-switch and run copies with no security lines.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 27, 2015 | Konica Minolta Bizhub C364 Color Copier /...
How to use beetel m59
want to program the short cut keys. can anyone please help me out
Jul 04, 2014 | Southwestern Bell Lands Phones
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
Please try this..
  3. Press Redial
  4. Replace Handset
Regards,
Jeep Brainy
Aug 10, 2009 | Toshiba DKT-2020-SD telephone
Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Apr 03, 2008 | NorStar M7324 Telephone
Setting Time and Date on phones
Just got this phone. It is indeed day/month/year. European style. NOT what we want for a phone in the states. Really annoyed with the fact there is not an option. Might be returning it.
Aug 19, 2007 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
336 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
