How to set year month date and time - Office Equipment & Supplies
SOURCE: date and month
There are three positions when you unscrew the crown stem. One does the day, one does the date and one does the time. You can also advance the date by rotating the crown stem and advance the time for 24 hours, as if a day passed. That takes a lot longer.
Posted on Jan 13, 2008
  • 13433 Answers
SOURCE: unable set time & date
Here is the user manual
http://www.sonyericsson.com/cws/download/1/265/274/1193035322/Z320i__UG_R1a_EN.pdf
Page 29 for instructions
Posted on Jun 18, 2008
SOURCE: Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Posted on Feb 17, 2009
for calandar
turn on.
press clock calandar button, top row second from left.
press time set button, second row from left, 3rd button from top, (has time set printed diretly above)
enter numbers, say 03 05 2009
press time set button 3 seconds
press CE/E, red key at bottom left corner.
turn on
press clock calandar button once, date will show
press clock calandar button 2nd time, clock will show
press time set once
enter time
press am/pm button (below time set)
press time set for 3 seconds
press CE/E red button to return to calculation mode
thats it
Posted on Mar 06, 2009
  • 244 Answers
SOURCE: the dd/mm/yyyy set every time
Yes it can be fixed but is a little difficult as the internal battery for the memory usually is a surfacemount ( solder type) battery which is soldered to the board.
You need a service manual for this camera to know what type of battery to replace. If you google service manuals for digital cameras you may find a down loadable manual for a small price.
Posted on Oct 16, 2009
Testimonial: "thank you. vic"
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
HOW DO I SET MONTH DAY AND TIME WITH BP3MW1-1W 800229
Below are the Date and Time setting instructions for a similar model: OMRON BP742
http://omronhealthcare.com/products/5-series-upper-arm-blood-pressure-monitor-bp742/
Set the monitor to the current date and time before taking a measurement for the first time. If the date and time are not set correctly, the measurement values stored in the memory and the average values may not be correct.
1. TO START THE SETTING
Press the Date/Time Setting button ( ) to adjust the date and time.
The year flashes on the display.
2. SETTING THE YEAR
The year can be set between 2010 and 2040. When the
display reaches 2040, it will return to 2010.
Press the Up button ( ) to advance by one year.
Press the Date/Time Setting button ( ) to set the current
year.
The month flashes on the display.
NOTES:
• Press the Down button ( ) to decrease the date and time values.
• Press and hold the button to increase or decrease the date and time values faster.
3. SETTING THE MONTH
Press the Up button ( ) to advance by one month.
Press the Date/Time Setting button ( ) to set the current month.
The day flashes on the display.
4. SETTING THE DAY
Press the Up button ( ) to advance by one day.
day.
The hour flashes on the display.
5. SETTING THE HOUR
The time is set using AM or PM.
Press the Up button ( ) to advance by one hour.
Press the Date/Time Setting button ( ) to set the current hour.
The minute flashes on the display.
6. SETTING THE MINUTE
Press the Up button ( ) to advance by one minute.
Press the Date/Time Setting button ( ) to set the minute setting.
7. TO TURN THE MONITOR OFF
Press the START/STOP button.
NOTE:
The monitor will automatically turn off five minutes after the minute has been set
SOURCE (PDF User Instruction Manual):
http://omronhealthcare.com/wp-content/uploads/BP742_IM.pdf
Jan 03, 2015 | Health & Beauty
Royal Time Master TC100 Time Clock - power went out How do I reset the date, day and time?
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month hope this help : - )
Jun 09, 2011 | The Times ROYAL TC100 TimeMaster Time...
How do you set the clock for manual clock in?
From the manual:
Press the SELECT button and position the cursor at the "TIME". At that moment, the "Hour" flashes. (The flashing means it can be changed.)
Change the "Hour". Press the CHANGE button to set the desired hour. Press the SET button. At that moment, the flashing changes from "Hour" to "Minute"
Change the "Minute". Press the CHANGE button to set the minute. and then press the SET button. At that moment, the "Second" starts to run from "00".
After you finish setting the time, press the SET button once again. Now the time setting has been completed.
Setting the Date
Press the SELECT button and position the cursor mark at the "DATE". At that moment, the "Year" flashes. (The flashing means it can be changed.) Change the "Year". Press the CHANGE button to set the year. Press the "Set" button. At that moment, the flashing changes from "Year" to "Month". Change the "Month". Press the CHANGE button to set the month. Press the "Set" button. At that moment, the flashing changes from "Month" to "Date". Change the "Date". Press the CHANGE button to set the date, and then press the SET button. After you finish setting the date, press the SET button once again. Now the date setting has been completed. Replace the cover.
Feb 28, 2011 | Lathem Time 900E Electronic Recorder,...
How do I set date and time?
  1. To set the current date and time, press and hold down the SET/EDIT button for 2 seconds, let go and the Month (M) and Day (D) indicators will start flashing.
  2. While the Month (M) and Date (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format, press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR and MINUTE fields. The field that is currently active will start flashing. To change a field's value press the LOCK button, each stroke of the Lock button moves one value up.
  4. Once you are finished setting the Date and Time press the SET/EDIT button to return to normal display.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189, and back up to the current year. Be cautious when setting the year
Resource 1: Dymo Date Mark Electronic Date/Time Stamper Manual
Feb 17, 2011 | Dymo Date Mark Electronic Date/Time...
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
  1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
  2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
    Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
  4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
I want to set the time and date on my calculator and need help Please give me the directions
1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
(The first digit of the date will flash)
3)Enter the date DD using the number keys.
(The first digit of the year will flash)
4)Enter the year YYYY using the number keys.
5)Press SET to confirm the date.
6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
Oct 24, 2009 | Victor 1208-2 Calculator
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Jun 08, 2009 | Microlife 3MQ1 Blood Pressure Monitor
Reset time
Nov 05, 2007 | Dymo DateMark Date/Time Stamper
23 people viewed this question
jasbo
jasbo
