Question about Refrigerators
Mspa temperature shows 21 degrees but, water Is still cold definitely not 21 and it's keeps cutting out help please
SOURCE: Rinnai rce-606tra II -- temperature is wrong
move thermister probe higher on back of unit
Posted on Mar 10, 2008
  • 531 Answers
SOURCE: My refrigerator cant maintain cold and freezer temperatures
check and see if the doors are closed good
Posted on Mar 31, 2009
  • 159 Answers
SOURCE: Our oven keeps tripping the electricity and we do
one of the elements are down to earth or too small breaker
Posted on May 15, 2009
  • 3 Answers
SOURCE: Motherboard temperature 97 degrees
no need to worried about the temperature budy i have the same mobo
my temperature is 91C while normal use and 96C while playing games and i have a dual core e2180 and the temperature of its is 66C as a normal use and 72C while playing game but my mobo work perfectly
Posted on May 10, 2010
  • 117 Answers
SOURCE: We have a Samsung American
SAMSUNG RSH1 COOLING PROBLEMS
youtube samsung video help click here
WATCH THIS VIDEO - links below video take you to ebay to purchase spares
video for RSH1 FRIDGE PROBLEMS
VERY HELPFULL WITH ADVICE ETC ">
Posted on Mar 20, 2011
My mspa inflatable bubble spa b-091 displays error code f7 and I cannot find any listing for that code
Error codes 2-5 are all water damaged electrical so I would say its probably that but to be sure you should contact them.
Email - info@the-mspa.com
Phone - 00-86-21-57402084 ( Shanghai , China headquarter)
Find a local retailer - http://the-mspa.com/care/show.php?lang=en&id=94
mspa-inflatable-bubble-spa-b-091-cva13tossffp5gzza31ixmk5-3-0.png list for b - 090
Aug 07, 2015 | Pool & Spa
Tip
I'm having the FH error. I'm am currently having plumbing troubles after leaving...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “FH” error code.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please post back if you can't find the tech sheet and/or need further assistance.
on May 27, 2010 | Kenmore Elite 45986 Front Load Washer
Refrigerator temperature shows 60 degrees but waterline is freezing
yes thermastat maybe bad check sencer for temp it maybe bad
Aug 29, 2014 | Refrigerators
What does SPH MEAN?
When you have an SPH error it means you could have an over heated power pack, or you have a water flow issue, or possible damaged equipment. Here is the three trouble shooting items you can look for.
1. Your water temperature is lower then 60 degrees (Turn the unit off and let it cool down and then turn it back on, this may fix the issue)
2. Your water inlet or outlet is blocked or partially blocked (Clean the inlet and outlet of the hot tub)
3. Your heater sensor is not working (you may have to replace the heater element or circuit board)
The SPH Error and how to Fix
Aug 24, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
I want to increase the available heat inside my car when it is very cold here in the winter. Do I use the 160 degree or 192 degree thermostat to get my heater core to be warmer sooner? This is probably a...
Hello. Not a 'dumb question', not at all.
You need a 192 degree thermostat installed. Ths keeps the coolant temperature at 192 degrees. That is the max temperature thermostat that is available.
If it is REALLY cold, you 'could' place a piece of cardboard in front of the radiator, and block 1/2 of the fins. This will keep the coolant temperature from decreasing very rapidly when the thermostat opens.
However, this cardboard trick is for sustained temperatures at or near zero F. Running the car with the radiator blocked in higher temperatures may cause an overheat condition, and you don't want that.
Thanks for the question.
Jan 05, 2010 | 1988 Toyota Cressida
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
