Instalation dip switches ( 1, 2, 3, 4)
With me problem on konica minolta 7235 show error code f35-8
1. Turn OFF the SW2 (sub power).
2. While pressing the copy quantity setting button 2
and 5, turn ON the SW2 (sub power).
3. [Software DIP SW setting screen]
Select a DIP switch number.
Use the or key or numeric
keys.
To use numeric keys, press the DIP
switch number key at the left before
entering a DIP switch number.
select Dip 3 1 to 0 from 3 1 1
Mar 22, 2016 | Konica Minolta Office Equipment & Supplies
Example the number of smoke detector is 39,what setting i use to the dip switch of the base detector.
It sounds like you have binary dip switches on the unit. If so, switches 1, 2, 3 and 6 should be on and the others should be off. on is up, off is down. Binary switches are as follows- 1=1, 2=2, 3=4. 4=8. 5=16. 6=32, 7=64 etc.
Nov 30, 2015 | Home
How do I get the remote to work fan and light
There are dip switches in the fan and in the remote that need to be set to the same numbers. You can set them to whatever you want, as long as they match. If these numbers don't match it won't control your fan.
Here's a few lines from the user manual:
"IMPORTANT! Before installing this control, check the factory dip switch settings. Refer to Figure 1. Be sure the dip switch positions of the transmitter and the receiver match, or the ceiling fan will not function."
Here's a link to the PDF manual, which has an explanation and a figure in the middle of where you can locate these dip switches on the transmitter and the receiver both.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/41316.pdf
Jun 24, 2014 | Hunter 27185 Remote Control
How to reset fuser error konica 7030
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day.
Setting Software DIP SW1. Setting method
This setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in
the non-volatile memory every time it is
changed.
Caution 2: The numbers shown in the message
area are defined as follows:
Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF.
Example: 04-7 : 1 A8
Bit data
1 : ON
0 : OFF
Bit number (0 to 7)
Switch number
2. Setting proceduresStep1
Operation procedure
Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on.
Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key.
Select bit number of the DIP switch.Use the center [  ] , [ ] key.
Select ON (=1) or OFF (=0) of the DIP switch.
Use [ON] or [OFF] key.
[ON] : Set bit.
[OFF] : Clear bit.
Press the [Return] key to return to the 25 mode
menu screen.For each switch function, refer to "List of Software DIP switches".
25
May 24, 2014 | Konica Minolta Bizhub C300 All-In-One...
Can I program a 10 dip switch remote to replace an 8 dip switch remote?
You should be able to, 8 dip switches gives you 256 addresses, the 10 dip switches gives 2048 addresses, just leave switches 9 and 10 in the off position and set the switched the same.
Jun 16, 2012 | FireFly 300mcd21k - 1 Button Keychain...
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
Jul 09, 2010 | Hunter 27185 Remote Control
Reset the error code e-5 on a ricoh ft4522
There is no need to use dip switches to reset this error code.Providing that the thermistors are good and they have been installed correctly,here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Aficio 450 Copier
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
My neighbors remote opens my garage door too!
Open your remote and there are dip switches that you set to be either on or off. Set them to any sequence you want, but you need to set the dip switches on your main unit to match the ones on your remote. For example: 1 off, 2 on, 3 on etc. Set the main unit to 1 off, 2 on, 3on and so forth.
Jun 28, 2009 | liftmaster Chamberlain Garage Door Opener...
23 people viewed this question
jasbo
jasbo
