Question about Epson Office Equipment & Supplies
How do i reset waste ink pad counter of epson stylus 1410
Inky
  • 691 Answers
SOURCE: Epson Stylus Photo R320
Turn off the power and look inside the machine to the right hand side. Just in front to f the print head you will see a white plastic dowel (see photo). Use something technical - like a finger, pen or screwdriver - to push this dowel in. You can then move the print head by hand to the middle of the carriage.
Once moved, turn the printer on and watch it travel back to the home position. If after returning home the dowel pops back out and does not retract itself, you will need to strip the machine out and rebuild the ASF section. Sounds hard but its just a few plastic parts to take apart and reassemble whilst looking to see if anything is broken.
Get a service manual; for the machine HERE if you need to strip it out.
Posted on Sep 19, 2008
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Posted on Apr 16, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
Waste ink reseter
You should have indicated where in the World you live! If in the USA, you can get a free reset utility from Epson.com. If anywhere else, you will have to purchase one - not expensive. Go to this website: http://www.octoink.co.uk/pages/Waste-Counter-Reset.html and you will find them helpful and, as mentioned, inexpensive. All done over the internet. One thing to mention is that the waste ink pads will be full - so fit a waste ink drain. Plenty of info around - just needs a spare (preferably glass) jar (as has some weight) and some tubing - most tool-type/ironmongery shops will have this. You will find this info valuable: https://www.youtube.com/watch?v=Y1cdvkJ-3Dc
Jul 27, 2014 | Epson Stylus Photo 1410 Printer
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
Jan 09, 2013 | Epson Stylus C67 Photo Printer
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
WHEN PRINT IS ON PRINTER HEAD IS NOT MOVING AND TWO RED LIGHTS ON
When both lights on the printer are illuminated it means the printer is at the end of it's usable life, you can reset this counter with software. EpsonIPRutilty
Michael
Mar 09, 2010 | Epson Stylus Photo 1410 Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Reset ink-pad counter on epson stylus photo 1400
Hope that helps.
May 12, 2009 | Epson Stylus Photo 1400 Printer
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Epson stylus 830Uink pads full not printing help
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
