Question about Tablets & eReaders
My icraig tablet is telling me it's needs boots configuration data. How do I get it?
My icraig tablet has got a pic of the prior owner and it can't be removed. And to compound that it won't even let me remove it. I have tried every thing, but l'm missing something.
Hi if u do a factory data reset it will delete it DONT FORGET TO BACK UP DATA .click on setting ICON u should find back up & reset .cheers
Nov 05, 2017 | Tablets & eReaders
Can i buy a new screen for my icraig tablet cmp759
Replacement Touch Screen for iCraig Craig CMP756 Dual Core 9 ...
  1. Cached
  2. Similar
Digitizer Glass Capacitive Touch Screen Panel Replacement for iCraig Craig CMP756 Dual Core 9 Inch Android Tablet PC Features: Brand new, original touch ... Missing: cmp759 Touch Screen/Panel Digitizer Glass Replacement Parts ...
  1. Cached
Buy Touch Screen/Panel Digitizer Glass Replacement Parts for CRAIG CMP738b 7" Tablet PC: Screens - ? FREE DELIVERY possible on eligible ... Missing: cmp759
LCD Display Screen Replacement for Craig CMP745e iCraig ...
  1. Cached
There are two layers of screen for a tablet. The one on the top is a touch screen, which works for the function of touch. The other below is the LCD screen, which ... Missing: cmp759
craig tablet cmp759 replacement screen - Buy Wholesale Phone ...
  1. Cached
Items 1 - 20 of 5498 - craig tablet cmp759 replacement screen - Wholesale craig tablet ... Craig tablet 746e screen replacement icraig CMP759 screen panel ...
Craig Electronics Inc.
  1. Cached
Whether you are looking for audio products like our Bluetooth/WiFi Speakers, or portable products like our Action Cameras, and Tablets, we bring you the ... icraig tablet cmp759 Google Search
Feb 01, 2017 | Tablets & eReaders
Why is my icraig tablet model# cmp801 not booting up after doing a system reset? The icraig screen comes on but then a black screen after that!
you can give it voice commands by pressing the mic top left corner I told mine to reset and it did it. let it charge up good then turn it on and look for the tiny microphone. say reset and let it do its thang
Dec 24, 2016 | Tablets & eReaders
Why does my icraig cmp765 tablet keep freezing
The solution to this problem is to reload the system software which you can get from the Craig Electronics website (Google it) and then select E-Digital from the menu at the right. Click on your product (CLP285) and you will see the software download and instructions for installing.
You will need an SD card to copy the software to. Power off the netbook, insert the SD with the new firmware and it will reload the operating system. When it is done, it will ask you to remove the SD card to complete the process. I have done this before, and it solved my problem. Of course, any data you had in the netbook will be gone.
Mar 14, 2016 | Tablets & eReaders
After hard resetting my tablet it displayed logo icraig for few seconds then went blank but u can see the tablet is still on but its sytuck on q black screen .
Sounds like the internal storage was wiped. Meaning not only the system was deleted but the whole tablet. Try again to wipe data/cache (never internal storage) and reboot the tablet. If it doesn't work, then you need to flash a stock image.
Feb 18, 2016 | Tablets & eReaders
My Icraig tablet always Locks up during the boot load procedure
Try resetting the tablet in Factory reset mode by pressing Power and Volume+ buttons simultaneously to turn on the tablet.
Feb 20, 2015 | Tablets & eReaders
Wipe my data partition
you need to boot into recovery mode to wipe the data partition. Doing this will reset the phone's data partition. Doing this will delete all data off the device and return it to the same state it was in when you first powered it on.
  1. completely power off the phone
  2. press and hold the power, volume up, and home buttons until you see the Samsung logo
  3. use volume up/down to scroll and power to select
  4. scroll to and select wipe data/factory reset
  5. select yes on any following prompts
  6. reboot device
If the above process does not work on your device, see alternate methods to boot into recovery mode in the following link.
How to Boot Samsung Galaxy Devices into Download Recovery Mode
Oct 18, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
My icraig tablet stays on loading screen always
Hi reset it to factory default and it should be fine, however you gonna loose all data.
Apr 11, 2014 | Tablets & eReaders
What kind of an sd card do i buy for my icraig tablet
The iCraig (CMP749) uses a MicroSD card, up to 32GB. Source:
Jan 23, 2014 | Craig CMP741d Tablet
Tablets & eReaders Logo
65 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
