Question about The Computers & Internet
I have a code 19 and can't seem to fix it. I uninstalled my camera software because it wouldn't recognize the camera, then tried to reinstall the software. I've uninstall it again code 19 still there
Riztech
  • 731 Answers
SOURCE: HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
Posted on Feb 11, 2008
SOURCE: Canon FB630u problem
I have struggled with this same issue for ages, I just found a fix from the HP site for the same problem with an HP scanner - it worked for my Canon LiDE70. Run regedit then:
  1. Double-click HKEY_LOCAL_MACHINE to open the folder in the left pane of the window.
  2. Double-click SYSTEM , CurrentControlSet , Control and then Class .
  3. Select {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} and check in the pane on the right for the Lower Filters string value.
  4. Right-click Lower Filters and delete it.
  5. Disconnect the scanning device and restart the computer.
  6. Reconnect the scanning device after the computer is restarted.
  7. BINGO! it worked!
Posted on Mar 01, 2008
SOURCE: Camera assistant software not working
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
go here pick your model number / operating system. download / save to desktop and install. note vista users right click and run as administrator. and then
1. Click the Windows Start button.
2. Click Control Panel, System and Maintenance and then Device Manager.
3. Right-click on Chicony USB 2.0 Camera and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver
4. Select Browse my computer for the driver software.
5. Select Let me pick from a list of device drivers on my computer.
6. Select USB Video Device from the list, and click Next.
7. If the message “Windows encountered a problem installing the driver software for your device” appears, click Close.
8. Restart Windows.
this bug is tricky good
Posted on Jun 07, 2008
suxia
  • 142 Answers
SOURCE: HP psc 1205 printer icon on system tray has exclamation mark
Better is to change USB port position. also ensure USB2.0 support is enabled in your BIOS. If some jobs waiting for print firs discard them and then install, but when you change port device installs automatically. Check cartridges for empty.
Posted on Aug 03, 2009
ITTech7574
  • 85 Answers
SOURCE: VX-1000 Initialization error
Better used the cd installer that comes with the camera make sure its compatible to your Operating System (Xp, Vista)..if this fails you have a problem with the camera...if you change the camera and still doesnt work..try to plug it in the usb at the back of your pc..maybe its just a power problem with the usb connection..hope this works! ITTech7574
Posted on Aug 28, 2009
Trying to upload photos from Largan Chameleon XP to Mr. Photo 3.0. The program keeps shutting down. The computer recognizes the camera as a new removable device, but as soon as I try to upload the photos,...
Listen, once your computer recognizes your camera, using windows explorer you can go into the innards of your camera and locate the pictures and simply copy them to any spot you want on your hard drive. U do not need any software to do that!
Apr 19, 2017 | NewSoft Presto! Mr. Photo 3
RE:QuicjCam UltyraVision- even though camera IS plugged in,program does n ot recognize this fcat. Multiple attemps and all available USB ports tried - and yet "CAMERA IS UNPLUGGED" persists. ...
try to uninstall and reinstall the program again
go to start control panel add or remove hard ware take it all out and reinstall then do a reboot
Jul 29, 2008 | Logitech Cameras
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you should uninstall and then reinstall the hardware device. (Code 19)
Try these options:
•Click Uninstall, and then click Scan for hardware changes to load a usable driver.
•Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Hope it helps.
Jul 10, 2010 | Microsoft Windows Vista Ultimate Edition
Computer do not recognize kodak c703 and the transfer station is not working
Hi
I just had this problem with my D5000. I did a lot of troubleshooting to discover a Windows Code 19 error in device manager. To see whether this is your problem, go to Control Panel, select device manager. Your camera should be listed under cameras/imaging devices. If there is a yellow exclamation mark, disconnect your USB/transfer station. Using device manager uninstall the software drivers. Once uninstalled reconnect the camera and usb or transfer station. Drivers are on the camera. It should begin an automatic reinstall. When it says your hardware is successfully installed, you should be able to use the transfer station again. If not, and you got a disc with your station, then I suggest uninstalling all the software and reinstalling. Apparently in windows operating system, if the registry entry relating to that device is damaging, it will no longer recognise the device nor load the drivers. The only way to fix the registry is to uninstall the device and reinstall.
good luck
Mar 02, 2010 | Kodak EasyShare C703 Digital Camera
MY DVD player does not work, error code 19.
1.You seem to be having a driver conflict. If you have installed a new software that uses the Drive, like a CD burning software, uninstall that software and try the drive.
2.May be your drive is not recognized. Use Microsoft Fix it. To do that go the link below:
http://support.microsoft.com/kb/314060
and follow the screen instrutions.
Feb 11, 2010 | Everex StepNote VA4103M Notebook
Hi, i have a toshiba L355 S7812 and just upgraded to 7 -- everything seems to work except for the built-in camera, and i cant find a driver/program for it....the toshiba program from vista doesnt work....
If the Vista Driver Doesnt Work, You Will need to search out a Driver from Different Make/Model... OR install software such as Driver Genius or similar to Install the correct driver for you...Or... try uninstalling and rebooting..
1) Bring up the device manager. You do that by clicking on Start button and then type 'Device Manager' in the search box. Select the "Device Manager" in the list.
2) In the list of devices, you will see "Chicony USB 2.0 Camera" with yellow bang on it. You will see either code 19 or code 1 as error codes.
3) Right click on the device and then select "Uninstall".
4) In the uninstall dialog, make sure you select the option to delete the driver package from the system. This causes the driver package installed earlier to be deleted.
5) Then in the Action menu of Device manager, select Scan for Hardware changes option. This will cause the device driver to be reinstalled.
Nov 23, 2009 | Computers & Internet
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Laptop Levono y530, device dvd rw optiarc AD-7580s I tried to uninstall & reinstall it, but...
Give this a whirl:
CD-Rom stops working. After checking device manager you find an exclamation mark on the drive. It doesn't mean the drive is dead. It could be an upperfilter or lowerfilter registry issue that is keeping you from accessing the cd drive.
This fix worked for my client:
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Also, try this fix from microsoft.
CD-ROM access is missing and messages cite error code 31, code 32, code 19, code 39, or code 41.
Try this before replacing the drive and remember that you may have to reinstall some burning software.
Oct 16, 2009 | Lenovo IdeaPad Y530-5243U
Computer won't recognize camera - Code 19.
Go here, and download revouninstaller. Install that on your computer.
Use revouninstaller to remove the original camera software.
Reinstall the the camera software from the cd that came with the camera.
If you don't have the cd, go to the camera manufacturers website and download from them and install.
Camera should then work.
Apr 18, 2009 | Computers & Internet
Guest
Rating: 0%, 0 votes
8. Restart Windows.
May 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Computer cannot detect camera at all!
This works for Windows98
1. Uninstall the Canon camera software.
2. Search for "Canon" in the registry. Delete ALL references associated with Canon camera in the registry. Just uninstalling the software will not work. Do not delete any other references to Canon products (printers, etc).
3. Re-install the Canon camera software.
I've had to do this several times. Works every time.
Jan 13, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Computers & Internet Logo
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
