Question about Refrigerators
Frig bussing on and off ..monogram model #zfgb21hxa ss. This unit never had the water option hooked up. It is 8 years old and developed an on off bussing recently
5 Suggested Answers
SOURCE: GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Posted on Jun 24, 2009
VtToolMan
  • 704 Answers
SOURCE: 42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Posted on Jul 13, 2009
duane_wong
  • 6826 Answers
SOURCE: I have an Amana side
I did a search on Amana.com's knowledge base and didn't find anything useful regarding your two top cooling units not working.
At amana.com, I tried to download the manual, but the service was unavailable until 8/9/2010 after 8:00AM due to system upgrades.
http://www.servicebench.com/servlet/WebSideServlet?Request_Id=APPWhirlpoolDealerLocateBrandedGoto&Request_Server=servicebenchpublic&Request_Brand=L1&Request_ReadUrl=Y
The above is a service locator for your refrigerator. Since their site doesn't seem to have a solution for this, I would call in the pros if you want to have it fixed more quickly than trying to do it yourself.
Posted on Aug 07, 2010
imufo2
  • 3773 Answers
SOURCE: Hello, I have a GE
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 10, 2011
How old is my unit
every refrigerator having a name plate at the back .,either a sticker or a metal plate tells you the model number ,size and year of manufacture.
Feb 28, 2014 | GE Monogram Side by Side Refrigerator
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
I have a GE side by side model #GSH25JSTA SS. It is 4 years old. The Water disenser stopped working about 6 months ago. We have replaced water filter and that did not seem to work. When we press the...
hey Jun, I have the same problem,, especially in the winter.. I just unplug mine for about 20 minutes,,,(DON'T open the frig while doing this!!!) .. seems to get the water flowing for me.....
Jun 14, 2017 | GE GSH25JSTSS Stainless Steel Side by Side...
I have a ZFSB26DND SS GE MONOGRAM side by side refrigerator. Serial number ZF416358. The freezer has thawed. The unit will not cool down. It was working fine Friday. I went out of town and came back to...
Unfortunately there is no one thing that I can give you as the cause...to find the problem will take a great deal of detective work or either your part or a service person.s part....
The problem could be a varied as a plugged condenser coil to a failed compressor or mother board..or a refrigeration leak...it will take a process of elimination to figure out the eaxact cause of your problem.
Many of these things will need a trained technician to diagnose...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 15, 2010 | Kitchen Ranges
I have an Amana side by side model ARS2664BW. The unit is about 8 years old. The water dispenser on the freezer door quit working and the cooling units inside the freezer and frig are not working proper....
Aug 07, 2010 | Amana ARS2464B Side by Side Refrigerator
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig. is bussing
it sounds like your water valve for your icemaker. if you do not have it hooked to water, it makes a lot more noise. try turning off your icemaker and see if the noise quits.
Nov 12, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
