I have a combo matic 6000. when it spins it shakes so badly I think it is going to brake thru its sides. did a weight come off? do I need new absorbers?
SFroese
  • 141 Answers
SOURCE: my maytag heavy duty fabric
This is probably the transmission.
Posted on Sep 06, 2008
IrishDruid
  • 2712 Answers
SOURCE: a Kenmore washer/dryer combo front
Check the bearings. I suspect they are faulty..
Posted on Sep 28, 2008
  • 333 Answers
SOURCE: While heavily applying the brakes at high speed the truck shakes.
If the front of the truck is doing all the shaking then the front brakes are doing all the stoppong. You need to check the rear brakes and change if neccessary. If they do not need to be changed then you should adjust them accordingly. I hope this helps. Don.t forget to rate my answer, thanks.
Posted on Feb 26, 2009
  • 55 Answers
SOURCE: car shakes bad on slight uphill around 2k RPMs
try CV joints or drive line , CV joints for front whell drive and drive line u-joints and drive line balance for rear wheel
Posted on Aug 05, 2009
  • 117 Answers
SOURCE: brakes
I don't know if the brakes dragging would cause the shaking or not but I will ask a question or two.
Does the car steer to the right or left when you apply the brakes? This would be caused by any leaking fluid or if one side is dragging heavily. This is because when the brakes heat up too much they begin to fade and loose there stopping power. If one side is dragging the car will pull to the other side when you apply the brakes.
You need to make shure that the brakes are clean and dry. Free from all grease or break fluid.
If a wheel is dragging the rotor will overheat and will cause "Blueing" of the rotors or they will look like they have small cracks in them.
Also did the shaking start imediatly after all the work or did it take a while?
Posted on Dec 21, 2009
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Steering wheel shaking during highway speed braking.
hav u had a professional alignment--cud be a # of things--u need a specialist--go to magicmechanic online and send him delemma--hes an expert on any make n model
Jun 24, 2013 | 2007 Pontiac G5 Gt Coupe
It recently started shaking hard that my steering wheel is vibrating...what could it be?
sounds like your front end is out of alignment check your tires for wear other than in the middle and take to tire shop to see if the tires are balanced right
Jan 24, 2011 | 1998 Ford Explorer
Steering shacks replaced steering damper still shacks
shakes?or shacks?Let's just say that you mean shake.If your brake pedal pulsates,replace the rotors.If your steering wheel shakes(low speed)broken belt in front tire.Jack up one tire enough to clear the ground,spin it.Spins nice,lower and jack up the other.Spin that one,if the belt is broke it'll be very noticable.While up in the air check the lug nuts,if they're loose it can make the steering shake too.If the shake is at highway speed,bad shocks or tie rods or ball joints or a combination of these.Jack up a front tire and try to move it(Key turned off to lock steering).If it moves top to bottom,ball joint.Side to side,tie rod.Doesn't move,shocks.The worst could be a bad hub bearing,but you'd hear it and you said nothing about any noise.
Nov 05, 2009 | Harley Davidson XL 1200 C Sportster Custom...
My washing machine shakes so much when spinning that it comes out of it's slot from under the counter. I think the weight in the machine has fallen as there is cement dust on under the machine
sometimes the concrete weights come loose, it will need to be dismantled ( back, top, front, off) to see where. could need new fixing bolts or screws. when weights have been refixed ,make sure the machine stands firmly on the floor on all four feet and doesn'twobble at all
Oct 05, 2008 | Whirlpool Washing Machines
Truck shakes when braking
You need to get the rotors turned and get new brake pads.
Aug 12, 2008 | Ford F-150 Cars & Trucks
Brakes
hello , it sounds like maybe you need to have your car alimement check .
Jul 05, 2008 | 2001 Toyota Camry Solara
Vibrates badly
did you remove the shipping braces when you installed it you can find their location in your owners manuel under installation
Mar 28, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
