Question about Garden
I meant to say briggs& stratton lawn mowwer 450 engine
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 152 Answers
SOURCE: oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
Posted on May 25, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area. Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... ( Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
http://www.brandnewmowers.com/pdf/11A-104B090EIPL.pdf
Thanks for choosing FixYa,
Kelly
Posted on Jun 28, 2011
Why is my 450 series 148cc briggs and stratton lawn mower engine running fine and then when it gets hot it runs with no throttle
Keep an eye on the oil level, it could be sucking oil past the rings and burning it causing the engine to run a bit faster. it may also have a small vacuum leak at the carb or manifold tube, make sure the carb and manifold gaskets are not leaking air. All combustion air must pass through the carburetor exclusively.
Jul 28, 2014 | Briggs & Stratton Garden
What kind of oil do you put in briggs and stratton lawn mower 450
generally, all B&S engines use SAE30 oil, however your local temperature range may make this an unwise choice. Google B&S Oil Chart
Jun 17, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
How to change the oil on a Briggs & Stratton 450
Sandy you can either drain the old oil from the spark plug socket which would be easier or the oil fill point. Remove the spark plug and tilt mower foward getting someone to hold a pot under it. When it's finished draining only put the same amount of oil back in (fresh) When you have done leave the mower somewhere level for a few hours and then start it. It may smoke for a few minutes.
Jul 21, 2013 | Garden
Cannot restart, without priming, my 8.75 hp Briggs and Stratton engine.
thats common for a old engine to have to choke it to restart it cold or hot
May 31, 2012 | Briggs & Stratton Briggs Stratton...
What oil to use 148cc briggs & stratton 450 series
main jet clogged and use plain 30 weight oil in it not not 10w30
May 02, 2012 | Briggs & Stratton Briggs Stratton...
I have just aquired a Briggs and Stratton 450 series self propelled mower but need an owners manual.
The Briggs and Stratton 450 series is the engine (4.5 Hp). Is there a model number on the mower deck anywhere? I can probably find you a manual but need that model number. Unless you just want an engine manual.
Murray makes a 20 inch MX450 that has the Briggs and Stratton 450 engine on it but there are numerous makes and models (self propelled) that use this engine.
MX450 parts manual is here:
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=lminvFXBnfBhU7y
If you can come up with a good model number I will search avidly for a manual.
Kelly
Jun 09, 2011 | Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
