Question about Video Game Consoles & Games
Data error code. Can't connect to wireless connection
  • 49 Answers
SOURCE: PS3 wireless connection ERROR code 8001000B
your wireless may be glitched and may need to be replaced or you need to reformat your ps3 which will return it to factory settings
Posted on May 20, 2008
bacigalupi9
  • 5 Answers
SOURCE: Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Posted on Sep 10, 2008
rahul26485
  • 611 Answers
SOURCE: Wireless connection using data one broadband
go the right click on the my network place then there is option wireless connection right click on it there option is there view avaliable networks go to it then you get the wireless option which is your just click on it then in the down there is connect button just connect it then he ask the password give it and one more thing is you sure that your wireless will enable ok
Posted on Apr 02, 2009
  • 18 Answers
SOURCE: Error Code 2753
The Microsoft Windows error "Internal Error 2753" is related to aWindows Installer failure. If this error is popping up as a prompt onyour Windows operating system,you will not be able to install applications on your system.Thankfully, there is an easy fix for this problem that you can performusing your systems DOS prompt.
  1. Step 1 Clickon the "Windows Start" button. Windows XP Users click on "Run," thentype "CMD" in the run box and click the "Go" button. This will bring upthe DOS command window. Vista users click on "Windows Start," then goto "All Programs," followed by "Accessories" and choose "CommandPrompt," and the DOS window will appear.
  2. Step 2 Type "regsvr32 vbscript.dll" without the quotation marks, and press the "Enter" key.
  3. Step 3 Youshould now see the message ""DllRegisterServer in vbscript.dllsucceeded," if this message appears, the required files for theinstaller have now been successfully registered, and you should be ableto install your apps.
  4. Step 4 Click on the installer file for your applicationand see if the error appears again. If the installation begins, thefiles are now properly registered. Repeat the process one more time ifthe installation still gives the Error 2753 message.
Posted on Oct 31, 2009
ZombieEmily
  • 60 Answers
SOURCE: wireless connection error code 32007
Wireless Router:
  • Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  • If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  • Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  • If you are still receiving this error code, please click here for assistance.
    Posted on Feb 08, 2010
    I am getting a message on my coolpad phone saying data error code unable to establish wireless data connection. What does this mean?
    you are recieving the error message due to weak data given by your network provider, try to change your location when accessing wireless data connection. go and find the strong signal outside your home.
    Dec 06, 2016 | Cell Phones
    I dont know how to set up the nintendo wi-fi connection
    1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
    2. Tap "Connection 1 None."
      emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
    3. Click on "Search for an Access Point."
    4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
    Once you have done this you may find next to your wi-fi, a lock this is what they mean:
    unlocked_g.png No security - Your wireless network is unlocked.
    1. Tap on your network name to select it.
    1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
    • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
      • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
    wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
    1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
    wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
    The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
    Jul 05, 2011 | Nintendo Video Game Consoles & Games
    I can't connect the wireless network even it shows that the wireless connection status shows as follows: connection status: connected network duration: going on signal strength: excellent However, the...
    Your router's wireless encryption setting (WEP) has been changed.
    Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
    May 02, 2011 | Computers & Internet
    When i connect my data card zte k3570z then a RAS error code 635 is displayed & connection failed please help me to solve this problem
    the RAS635 error requires you to contact vodafone, probably the vodafone adapter is faulty from past experience
    Apr 17, 2011 | Vodafone Mobile Connect (055270) Wireless...
    Invalid command, line 01 code 400
    Mornach 9825 printer is error "Invalid Command! Line 01 Code 400 ".How issue this error.
    Apr 16, 2011 | Monarch Paxar 9855 Printer
    Won,t connect to wireless broadband. Error code
    Error Code: 5130 Specific Error Code Not Found - General Troubleshooting
    • Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
    • Check your router's broadcast settings to find out if it is set to "G", "B", or "Mixed." Mixed typically works best, but try all three to see if it improves the network connection to the Wii console.
    • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off. Wireless keyboards and mice may also cause interference.
    May 14, 2010 | Nintendo Wii Console
    Error code 32032 (wii)
    you need to set up connection for wireless if its a wireless router then set it as connection 2 then search for your router then input the wep-psk or wpa psk code thats on the back of the router
    Jan 23, 2010 | Nintendo Wii Console
    Wireless data connection
    hi!!!!!!!!!
    try to configure out first the router!!!!
    may be it has network password or security key
    Sep 23, 2008 | Cell Phones
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
