Question about Kitchen Appliances - Others
Gourmetliving toaster maual model KT 3114
4 slice toaster.
SOURCE: duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Posted on Nov 05, 2007
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
SOURCE: 4-slice egg & muffin toaster
On my fourth one now...love the idea, but the egg poacher keeps burning out.
The 800 number is 1-800-688-1989
Calling them now...this last one only lasted 3 weeks.
Posted on Jul 28, 2009
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
espressonist
  • 1711 Answers
SOURCE: Our 4-slice toaster (model 4cbc) is only toasting
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Posted on Apr 02, 2010
What is the purpose of the switches and light s on the front of the Toaster
Hello, Can you please post the full name and model number and serial number of the toaster you have a question on? You posted this question under Haden 10941 4-Slice Toaster and those numbers with a hayden brand do not match. I await your reply. Thank you
Rick
Nov 06, 2011 | Haden 10941 4-Slice Toaster
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
Where can I get operating instructions for the Tefal 5327-16 four slice electric toaster?
Hi there.
I have seen an Avante Deluxe 4-Slice Toaster Owner's Manual at http://www.t-falusa.com
You can download this if it matches the model of your toaster.
Regards.
Jul 18, 2011 | Kitchen Appliances - Others
When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Only toasts one side of toast
The cancel button is stuck in the in position
Jan 13, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Wiring diagram needed for 3 slice dualit model auto 3
get it at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Aug 06, 2008 | Dualit Vario 3 Slices Toaster
Duraband 4 slice toaster manual model # TS-5221
ok...
When:
Where:
How:
WARNING:
Oct 14, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
