Question about Toaster Ovens
THE DOOR WILL NOT OPEN ON THE TOASTER OVEN, IT MOVES A LITTLE AND IS GETTING CAUGHT. SUCH A SIMPLE MECHANISM IT HAS NEVER HAD ANY PROBLEMS BEFORE
SOURCE: toaster oven
THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
Posted on Feb 24, 2008
SOURCE: Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Posted on Sep 12, 2008
SOURCE: Toaster oven door
Try sales@semenedis.com They do thousands of parts for white goods.
Posted on Dec 03, 2008
SOURCE: toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Posted on Mar 31, 2009
kebah
  • 684 Answers
SOURCE: We have an old Oster
Hi there.
Try http://www.oster.com
You will be able to find authorized parts dealer near your area.
Regards.
Posted on Jun 29, 2011
The door would not close properly
www.brevilleusa.com/the-smart-oven-r.html
Website includes support. The door problem is most likely mechanical in nature and possibly could be found by simple disassemble, by anyone mechanically inclined. .
Jun 06, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
Euro pro to241r
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Oct 10, 2013 | Toaster Ovens
Door does not close
After 3 years of perfect service, our toaster oven's door stop closing easily. After reading the internet and trying to contact Cuisinart for a solution I was stumped and frustrated. Someone on the internet mentioned using wd-40, but I didn't want the smell when I toasted! I try cleaning the metal arm that held the glass door using an alcohol pad and that actually helped a little! After thinking about something to lubricate the door are with that won't smell awful and hopefully won't catch fire -- I decided to try olive oil! I took a little, very little on a paper towel and rubbed the metal arm a few times -- It worked!!!!!!! The Door now closes with the greatest of ease! and doesn't smell awful when you toast, so far it has not caught fire. Give it a try! I love to give it 4 starts, but Cuisinart support didn't have a solution... I'm sure even if I suggest to them my fix that won't share the info, but use at your risk! I am certainly not responsible for any mishaps that may occur if try my fix, but worked for me.
Dec 31, 2010 | Cuisinart TOB-50 Toaster Oven with...
Main problem, bottom two elements have conked out. Where do I get new ones? Next, how clean glass door when it won't come out of slots? Next, what do I use to clean shploops patina off crumb tray?
you can get the new elements from the online sites mentioned below www.repairclinic.com also from www.partsselect.com and for cleaning follow this instructions
  1. 1)take out a bowl and in that bowl make a paste using the baking soda and vinegar
    2)After making a paste open the oven door with the oven off. Take the sponge dipping it into the paste of vinegar and baking soda.
  2. 3) After dipping it into the paste. Smear it on your oven door. Leave on for about 10-15 minutes longer for more stubborn stains. Now the time is up! take that sponge rinsing it in water and wipe down. Little or no elbow grease is required. Now you have a beautiful oven door.
    This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Mar 04, 2010 | Bella Cucina 13049 1500 Watts Toaster Oven...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Toaster oven door
Dec 03, 2008 | Black & Decker CTO9000 Dining-In Toaster...
Toaster Oven Repair
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
Toaster oven
Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
Toaster Ovens Logo
163 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
