Question about The Computers & Internet
My camera SD card is suddenly not recognised in my windows 10 laptop?
It has worked okay for months now doesn't appear in the drives. It is recognised perfectly well in my husband's laptop, so not the card. There are no yellow exclamation marks in device manager. How can I get it working? Fixed! I found the SD card driver was missing. Couldn't find it online from a reliable site, but turning off the laptop, removing the power source, holding down the power key for 5 secs and then turning it back on reinstalled the driver. Thanks for your comments, phew!
joey64
  • 209 Answers
SOURCE: On board Ethernet adapter
if you uninstalled then reinstalled the driver and the adapter you must restart you computer to reflect the changes
Posted on Dec 08, 2007
  • 243 Answers
SOURCE: dimension 4600 cd/dvd drives not responding
Try uninstalling them in devive manager then rebooting and see
if they are reinstalled automaticaly as drivers should be in xp already.
Just right click on them and select uninstall.
If that doesnt work then try update drivers and let xp search online for them.
Failing that then try changing the cable thats attatched to the motherboard.
Hope that helps? :)
Posted on Jan 04, 2008
philmik
  • 107 Answers
SOURCE: USB Drive not detected by computer
Try to install latest chipset drivers for your motherboard. If you don't know what motherboard you have, you can download Everest and it'll give you all needed info.
If after install you still have this problem tell me, and we'll try to find a solution.
Posted on Feb 20, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Not displayed in my computer, but displayed in device manager with yellow exclamtion mark code39 driver error
Hello there:
here is a few things to check
first check to see if bios is set up with the cdrom listed as part of the boot sequence. if not change the boot sequence. than save and reboot
next if you know how to remove the device turn off the computer and remove the device than power on the computer and let it load than turn off as normal than reinstall the device and reboot and it should recognize the device than search for drivers for the device
please try these ok
best regards mike
Posted on Aug 08, 2009
laikexpert
  • 281 Answers
SOURCE: Pen drive does not recognise
1. Download:
Kingston 512MB DTI Win98 Driver
2. Install
Posted on Feb 02, 2010
My samsung S500 has suddenly stopped recognising the sd card
Try formatting the sd card IN the camera. Never format an SD card while it is in the computer.
Jul 22, 2016 | Samsung Digimax S500 Digital Camera
When i put the memory card in, it says not supported card
Did the card work in the camera before? If it did and suddenly stopped working, it is possible that the card became corrupted. One possible way to fix this is to format the card. If you search through the menu or setup screens in your camera, there should be an option called "Format" which will erase all the data on the memory card. This is basically like a reset button, clearing the card.
Alternatively, if you cannot find the "Format" selection on your camera, you can insert the card into your computer and format it from there. On a Windows computer, in My Computer, just right click the SD card when it appears, and select format, then okay. For Macs, Cntl + click on the SD card after you insert it, and format. Hopefully this will work. If it doesn't, it's likely that your card has died and it's time to replace it.
Dec 06, 2012 | Cameras
Laptop running Windows7 previously mounted Nikon D70 (camera) as Mass Storage Device but, stopped recognising it. Camera sees laptop?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Nikon Transfer.
Jul 01, 2012 | Cameras
Sigma 4in1 card reader not working
Try a different / all other USB ports on the computer, and if possible, a different computer if no USB port on your computer works with it. If it still doesn't see the drive, the drive is probably not working. If it does see the device, but is asking for drivers, provide a disk with drivers that came with the reader - or check the Sigma web site for drivers that work with you OS (Windows, Mac, etc.), download and install / extract.
If it sees the device, but doesn't see the memory card, the reader may not recognize the newer, larger capacity memory cards. SD cards are smaller than 4GB in capacity, and SDHC cards are 4GB and larger. Make sure that if you're trying to read an SDHC card that the reader SPECIFICALLY says it works with SDHC cards. Most SD readers can NOT be upgraded with firmware to be able to read SDHC cards - a new SDHC reader is required.
Jan 30, 2012 | Cameras
My computer doesn't recognise Digimax201. Recognised 1 time, no more since then, not able to download pictures..
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery on Windows.
Aug 09, 2011 | Samsung Digimax 201 Digital Camera
My 1 gb micro sd card is corrupted and my nokia E63 phone and DELL inspiron is not recognising it
    • 1 If your aim is to repair a corrupted SD card so that you can use it to store files then proceed to step #2.
      If your aim is to recover the files on the SD card without erasing them, proceed to step #5.
    • 2 Insert the SD card into a digital camera card slot and choose to format your card. If this doesn't work then move on to the next step...
    • 3 Place the SD card into your computers SD card slot.
      Right click on the SD card drive letter IF it appears and choose to "format."
      If this doesn't work, proceed to the next step...
    • 4:You will need to go to the website
      http://www.sdcard.org/consumers/formatter/eula/
      Here you will download, install, and run the program to format your SD card. This is the most advanced step of the three, but most likely to work 99% of the time.
    • 5
      If you want to recover files ON your SD without erasing them, then you need to download and run the software on this site.
      http://www.cgsecurity.org/wiki/TestDisk_Download
      This is the best free software available for this type of problem.
Jun 02, 2011 | Maxell 4 GB Class 6 Micro SDHC Card with...
How to copy older IXUS100 images from the desktop to the IXUS100
In theory a card reader should enable you to see SD card as a drive.
You should also be able to see the card as a drive if you connect your IXUS to the computer-then you'll be able to copy the images back onto the card.
Good luck,
Raf
Nov 08, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
I have inserted an SD Card (2GB) into my Alba pocket camcorder and nothing appears to be working on the camcorder. There is a small red light showing underneath the Rec and Zoom in/Out controls but apart...
Hi!
Have you inserted a new SD card? If this is already a used one, you can try to reformat it and then test with the Pocket camera again.
With the issue on the device recognition on your Windows PC, you should make sure that the correct driver is installed.
Will wait for your reply.
Aug 27, 2009 | Video Cameras
Computer won't recognise my Nikon d60
dont bother to connect camera to pc..just use the SD card reader...either external usb one or laptops internal one
Dec 19, 2008 | Nikon D60 Digital Camera
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Darren  Means
Darren Means
d3yavu3
kimblebear
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
