Question about HP Office Equipment & Supplies
How do i get rid of HP ORIGINAL INK DEPLETED ON C6280 ALL IN ONE PRINTER?
I AM USING A CISS
    Master:
  • 347 Answers
The empties you can drop at any fry's or anywhere they refill ink empties
Posted on May 07, 2017
Alarm po2 after off the power only 4 print and alarm again po2 then afte off the power again only one and alarm again po2
  • p02 is normal issue clean the purge unit and align carriage plate screw problem is solved
  • Or you are using ciss tank properly fix the ciss tube problem willb solved
Mar 15, 2014 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Canon ip 7240 i used refill ciss but 4 flash
Hi, My name is Liam from rihac, although we do not sell printers I work very closely with them via our inklink products. When a printer flashes 4 times this is a sign that an ink tank is not installed correctly or that the cartridge will need to be replaced as it is low on ink. As you are using a CISS the cartridges will always have ink in them. To bypass this error all you will need to do is press and hold the RESUME button on the printer for 10 seconds and this will turn off the cartridges ink status monitor and allow you to continue printing.
Canon Error Codes
I hope I was of help to you
Oct 30, 2013 | Office Equipment & Supplies
I have my EPSON TX121 for almost 4 months and i installed it with CISS. I learn also to reset the waste inkpad counter and it work okay. My new problem is, the printer is starting again telling me a...
If you have a set of cartridges there try removing the CISS tanks and using them. If it recognizes the cartridges than the master chip on the CISS Tanks are faulty. Its usually the black.
Contact the manufacture for replacement chips if available.
I Hope this helps, if so please rate my response Thank you for supporting the FixYa Community
Regards GM
Apr 08, 2011 | Office Equipment & Supplies
Can i get to convert my brother dcp115c to ciss . thanks
It can be But the warranty might get void. There are other types of CISs that wont void brothers warranty this CISs can be installed outside, and nothing to do technically inside your printer, better ask the store about this kind of CISs.
Feb 03, 2011 | Brother DCP 115C All-In-One InkJet Printer
Im using ciss for my epson cx3700 and the magenta wont print anymore
Make sure there is not an airlock in the magenta ink line. This is best achieved by fitting a syringe to the flow line and sucking through some ink. Also you may be able to use a syringe and needle to inject some in into the cartridge to prime it. You may need to run several cleaning cycles to get the ink through - I had a similar issue with and Epson R300 using CISS and carried out over 10 cleaning cycles to get the yellow ink to flow again. It may also be worth removing the cartridge and leaning the exit area with a cotton bud soaked in isopropyl alcohol as residue can build up in this area. If the problem persists you can fill the cartridge with cartridge cleaning fluid to flush it through and then empty it and reconnect the CISS ink supply. If you disconnect the CISS Supply a good tip is to use a bulldog clip to prevent the ink from siphoning out of the supply line while you are attending to the cartridge.
Oct 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson CX5500 with CISS ink supply not printing
Ive replaced all the cartridges on my epson 5500 but still nothing prints. Any help gratefully received
Jun 19, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Error massage not compatible ink cartrage when using ciss supply
Solution?the solution is never to buy an epson printer ever again! i bought mine early last year with the CISS and since then have give me that same red lights problems like .. forever ! the solution is to sort of take off the carttridge and put it back again. u might have to do this a few times before it actually work . and oh yeah , you have to print everday with epson cause otherwise the ink will clog !! mine is already clog, i have to buy the original ink now to unclog it but still it produce lines! Since then i have give up hope and put my epson in the box to end my misery . i;m using Canon Pixma MP142 with CISS and till now no problem !!
Jan 02, 2009 | Epson Stylus CX5400 All-In-One InkJet...
R265 printer
hmm the only thing I can think is that there is a issue with the ciss system, but cant be sure unless tested which would mean new carts being bought but could it be possible if the ciss system got plugged?
I have not used the ciss setup before just used one never looked into them fully before.
Let me do some more reading and see if there is anything else that I can add to this, I need more education on the ciss system my buddy owns a ink refill place so im gonna see what he has to say.
Aug 13, 2008 | Epson Stylus R265 InkJet Photo Printer
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
