Question about The Health & Beauty
What does hand symbol mean?
I need to know what the hand symbol on the wrist blood pressure means?
    New Friend:
  • 8 Answers
It is your heart beat or your pulse. If you notice there is another number just below the blood pressure reading. that is your pulse.
Posted on May 07, 2017
What does the heart on the monitor means?
The blinking heart symbol indicates that the unit is slowly decreasing the pressure in the wrist cuff. This is when the unit is finding your Diastolic blood pressure. This is a normal symbol on most automatic blood pressure monitors. When a nurse or doctor uses a manual blood pressure cuff and listens to the blood flow, they will record the systolic pressure when they first hear the heart beat. Then they record the diastolic measurement when they can no longer hear the heart beat.
The manual for the KS-7902 is available here: http://pharmasupply.com/wordpress/pdf/wristman .
I hope this helps.
Aug 08, 2014 | Advocate Wrist Blood Pressure Monitor...
Wristech blood pressure Moniter Model # HL-168
1) Try to get the band as tight around your wrist as you can with the sensor part of the strap across your wrist nearest the palm of your hand, and try it again.
2) Try changing the batteries. They sometimes start to error like this before the batteries show as weak/dead.
Jul 03, 2014 | Health & Beauty
WHAT IS THE P IN A CIRCLE FOR IN THE WRIST BP CUFF
What does the circle with a P in it mean on walgren creen of cuff bold pressure monititor?
Jul 30, 2012 | Walgreens By HoMedics Automatic Wrist...
Lost the instructions to the HOMEDICS ULTRA DELUXE 520 and need to know what the symbols mean regarding IRREGULAR HEARTBEAT.....
To obtain a copy of the manual call HoMedics Customer Support1-800-466-3342. Have the Model Number handy, when you call.
Hope this helped you and thank for choosing FixYa.
Aug 25, 2011 | Walgreens By HoMedics Automatic Wrist...
How do you read a wrist tech monitor and what does the number mean?
The wrist monitor, much like ones in doctor's offices, reads your blood pressure and pulse rate.
The large numbers are your blood pressure reading. The Top number is the Systolic and the bottom number is the Diastolic. If you doctor or his nurse has taken your blood pressure and told you what it was, they said for example, 140 over 80, which on your chart would be listed as 140/80. The smaller number at the bottom of the screen is your pulse rate. Some monitors will indicate if the heart beat is regular or irregular. Depending on your age, general health and life style, a normal blood pressure would be in the range of (Systolic) 120 to 130 over (Diastolic) 70 to 80. But, your normal range may be different based on what I said above. Only your personal physician can tell you what yours is or should be.
When using a wrist monitor it must be properly placed on the wrist (1" above the heal of the hand). You must remain very still and try not to talk, until the monitor has completed cycling. Also, having your hand/wrist at heart level, helps to ontain a more accurate reading. Never take readings back to back. Wait at least 2 minutes in between sessions.
If this helped you, please be kind enough to let me know.
Rich
EMT
Mar 16, 2011 | RTO WrisTech Blood Pressure & Pulse...
What does EE mean?
EE means one of 3 things:
1. Cuff has been placed incorrectly. Solution: Wrap the cuff properly so that it is positioned correctly.
2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady during measurement.
3. Shaking of the wrist with the cuff on. Solution: Same as # 2.
Jan 25, 2011 | Walgreens By HoMedics Automatic Wrist...
It always indicates error on the wrist monitor even though i changed the batteries and place myself in the right position at heart level . is there something wrong with the monitor.
You can try BOTH wrists, not that this should make a HUGE difference, usually it is the actual pressure itself. I would try to use to machine on someone else and make sure that your actual pressure(meaning the amount of blood, rate of flow) can be monitored with a wrist model. Some people are forced to use a arm style..... take care... Guy
Sep 17, 2010 | Centrios Wrist Strap Blood Pressure...
Starts to inflate then get "E"
When you wrap it around your arm, make sure the cuff is just above the elbow and the air tube lines up with the middle finger of your hand. Try various locations -- the 'E' just means it is not sensing your heartbeat.
Jan 12, 2010 | Omron HEM-629N Portable Wrist Blood...
I've lost the directions for the Mabis Wrist Monitor 04-235-001
The heart symbol means your pulse rate and the page is the memory page
Mar 28, 2009 | Mabis Blood Pressure Monitor Smartread...
Blood pressure measurements support
There are two positions for taking your blood pressure measurements: Sitting down - Place your elbow on a table. Using a flat object as support, position your wrist at heart level. Your blood pressure measurement will be too low if you hold your hand too high, or too high if you hold your hand too low. Lying down - Lie on your back. Rest your wrist on a support or cushion with the palm side facing up, position your wrist at heart level. On both of the positions you need to open and relax your hand with the palm facing up (closing your hand will cause inaccurate readings). Do not bend your wrist inward, as bending your wrist will cause inaccurate readings. If possible, empty your bladder before measuring your blood pressure, for a more accurate reading.
Aug 27, 2008 | American Diagnostic Corporation 6016...
Health & Beauty Logo
Top The Health & Beauty Experts
Megan S.
Megan S.
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
