Notg nshhr j - Computers & Internet
Code p0449 will notg erase
then your problem is still present, have you replaced the vent valve, check the wiring and have you cleared the codes if not you need to do that just replacing the part will not clear the code it will become a history code after numerous drive cycles
Jan 17, 2013 | Chevrolet Silverado 1500 Cars & Trucks
I have a light on the dash it a engine light can anyone tell me if the car needs a service and can i turn it off it cant be a lot the car runns like if it was new
well i would scan the ecm to see what has trigured the code. ..Make sure its notging serious...,request freeze frame data. ..this can be done at autozone etc....please post the code thanks...
Aug 02, 2011 | 2003 Jaguar X-Type
When I turn the amp on I hear a blop blop blop etc etc sound. I tried everything but notging seems to work. The diods are ok, the solderings are ok the LM1875T seems OK. What could this be? How can I solve...
This sounds like a DC feedback problem in the power amp. Check all the resistors R86 through R96. Verify that capacitor C80 is healthy. The right tool to solve this is an oscilloscope.
Feb 03, 2011 | Marshall Amplification Marshall 15 Watt...
Rear tail lights notg working? parking lights not working & dash lights not working all at once. Have looked at fuse panel under driverside dash... nothing saying rear tail lights fo a fuse? can you...
Thank you so much Twobrandsam. Was having the same problem and could not find it until I read your comment about "Small lights fuse." you saved me a lot of headache. Thanks for sharing your solution.
Oct 03, 2010 | 2003 Honda CR-V
Pull both battery cables, let the car sit for 20 minutes then put them back on.
Feb 25, 2010 | Vehicle Parts & Accessories
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
try replacing the relay in the middle of the ignition and starter.
Apr 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Six blinking red lights when trying to turn on.
The power supply board went dead. Have it repair or replaced. No other way around this. Thanks, mike H.
Nov 26, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Radio wave remote controll
Im sorry but from our knowldge directv does notg have a radio wave remote. But all of directv remotes are universal they are compatibale with almost any other home entertainment device. Your directv manual should help you with this, and directv has moed to one standard remote for there equipment it is the RC64 they did to get away from some of there older models this remote wil run it all.
Please Rate
Jan 13, 2008 | RCA DIRECTV Satellite Remote Control
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
