Question about Refrigerators
Display on french doordoes not work butfrig and freezer work well
Code freezer demo
French Door: Why Does The Control Panel Display "OF OF" Instead Of The Temperature? If the control panel displays "OF OF" instead of the temperature, the refrigerator is in "Cooling Off" mode. In Cooling Off mode, the refrigerator appears to be running normally, but the compressor is off so the unit does not cool. Cooling Off mode is used by retailers to save energy when the refrigerator is on the showroom floor.
Note: Cooling Off mode is also called Demo mode or Exhibition mode.
Disable Cooling Off mode by performing the following:
  • Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
Source:
Why Does The Control Panel Display OF OF Instead Of The Temperature...
Oct 17, 2014 | Samsung RF4267HARS Stainless Steel French...
Samsung refrigeratore display says OF
i hade same problem ,my refrigerator was in display mode,light working, but no copressor or ice maker, ch in the manual it tell how to and wat button to push to start in working mode
Feb 15, 2012 | General Electric GFSS6KKXSS Stainless...
My digital display reads 88 degrees for the fridge and the freezer. The 88 display on the right is flashing. None of the buttons work when pressed.
reads 88 deg/ ok is frig that warm also .. if so replace the p c control as it has gone bad . in some models they call it a jazz board . / there is a update and it works much better .. mm
Dec 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
The display panel want work.
LOOK MIN TH EBACK ON THE MAIN CONTROL BOARD AND THERES A FUSE THAT YOU MAY HAVE BLOWN
Mar 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
Maytag french door fridge no cooling in fridge section
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
Jun 28, 2008 | Maytag Refrigerators
LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Apr 02, 2008 | LG LRFD25850 French Door Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
