Question about LG KM900 Arena Cell Phone
Screen replacement km900
I have trouble with opening the body.
The screws are out opened it for a bit but
The last part won't come loose
How do I open the case on a Radio Shack Presidian boombox cat number 14-108
check for a tab ( bit of paper)with a name , number or writing on it as manufacturers use it over a screw to determine if the unit has been interfered with when a warranty claim has been made
pressing in the center of any paper stuck to the back may reveal a hole underneath in which will be the last screw
Dec 29, 2015 | Audio Players & Recorders
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Loose screen hinges on lg laptop.
Yes, get on eBay and purchase LCD Hinges
Apr 20, 2012 | Computers & Internet
1999 s70 volvo driver door won't open from outside or inside
I am working on this RIGHT NOW. Remove panel (see Utube) remove white cover (Torx 25) from interior of exterior handle. You will see that lifting the handle pushes a rod down The rod is attached to the bottom half of the mechanism via a cheapo plastic connection, that can work loose. It is like a screw shaft (top) that squeezes (sideways) into a blue plastic channel which merely pinches the "screw shaft" to hold it. The connection has come loose. Squeeze upper shaft into (lower) blue channel. Added tiny bit of epoxy to bond "screw shaft" onto blue plastic gripper. Done. Saved $500.
Apr 04, 2012 | 1998 Volvo S70
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
Sony PlayStation 2 Slim disk only spins if door is a little bit open, I even put something on it so that it won open or shuts completely, because if it does, then it doesn't work,for reference, it was...
tray problem can be solved by opening the ps2
1. unscrew all the screw open the body
2. on the upper body u can see a spring on the tray
just clean the spring (dust particles)
3.cover the tray check whether it is working
Mar 22, 2010 | Sony PlayStation 2 (PS2) Console
CAN YOU TELL ME HOW TO INSTALL EXTRA MEMORY IN MY ACER ASPIRE 5315 LAPTOP HOW DO I REMOVE THE KEYBOARD ETC
The memory is under the laptop. Turn the back, remove the battery, you will see alot of small screws, loose them all one after the other. But if you want to loose the memory, you do not need to remove all the screws, look very well you a cover that has about one or two screws, there you will find the memory. Also you will see a screw under the DVD/CD Drive, you need to loose the screw first before you can remove the drive.
As for the keyboard, after loosing the screws from under, turn the laptop back up, open the flip, try removing the front cover, before you can reach the keyboard. After opening the cover, you need to remove the keyboard flex carefully.
After loosing the screws, you might find it a bit difficult to open the laptop cover, you will need force to open it, but becareful so the nothing will get spoilt or broken.
It's very simple, just make sure all screws are loosed before you try opening.
I wish you the best.
Nov 17, 2009 | Acer Aspire 5315 Notebook
How to change the back light
Open the rear door and look for 2 pop-off caps on the suspected tail light assembly covering philips screws. If you remove both screws, the tail lightassembly becomes quite loose.
The last step is to give a firm tug, directly backward. The whole assembly is held in place with three small plastic clips (round cone shaped devices pushed through holes in the rear body work with a rubber "washer" protecting the paint).
You have to pry them loose from their insertion mounts to remove the assembly. A firm tug works well, but don't pull to the side or you may break the clip (or clips), and then have to replace those too. Once you've pulled the assembly off, the lights are easily accessed and replaced.
To reassemble, simply reverse the process.
[Note: there is no cover for the bottom screw on the rear door hinge side. It is exposed. There are two possible bolts on the bottom side of the door; the one for the tail light assembly is the one you can remove with a philips head screw. It can be accessed by opening the door and fitting a screw driver through the opening behind the door.]
Nov 07, 2009 | 2004 Honda CR-V
Tool to open fuji finepix j150w
where did you buy the replacement screen? I just broke mine :(
Sep 22, 2009 | Cameras
LCD screen nonresponsive
if your . . . remote . . . works ok ? your touchscreen internal connector could be loose disconnected - or defective ( not field repairable ) ;
Oct 20, 2006 | Sony Handycam DCR-HC30 Mini DV Digital...
LG KM900 Arena  Cell Phone Logo
616 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
