Question about Makita Saws
I have no power on Makita LS1040, changed carbon bushes, any ideas
    Novelist:
    Scholar:
  • 86 Answers
Check the switch 651923-1 SWITCH, LS1040 behind the 415999-0 SWITCH LEVER, LS1040.
If you don't have the parts list, here's a link: https://cdn.makitatools.com/apps/cms/doc/prod/LS1/920e0c9d-cebc-452a-a06b-39ff7a832dc8_LS1040_PB.pdf
Posted on Jul 04, 2017
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
How do I lift the saw mechanism on a Makita LS1040. It is locked and cannot trace any release mechanism. Danie
It's on the righthand side of the saw at the hinge area in the back. If that is unlocked then it could be the guard linkage hanging up.
Feb 16, 2015 | Makita Saws
How to fit compression spring on makita LS 1040 mitre saw
Go to: http://www.ereplacementparts.com/makita-ls1040-miter-saw-parts-c-97_98_99_323.html. They also have a video on how the replace the blade. Look closely at the parts diagram to see how and where the spring fits and fit accordingly.
Sep 09, 2014 | Saws
I can not remove armature caseing from makita miter saw
The casing at the saw end will have an inside case that is bolted either from behind the gears or from the armature side by screws. This has to be undone to allow the bearing to separate from the case
Jan 16, 2013 | Makita 10" Compound Miter Saw LS1040
I have a Makita 10 inch compond mitre saw. My owners manual has been lost and I need the tables that show what degree to set the mitre and bevel for various degrees.
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
Jun 08, 2010 | Makita 10" Compound Miter Saw LS1040
My makita sliding mitre saw is off a few degrees How do I adjust...non laser...10''
move the blade until it is square to the fence then loosen the screws on the table with the degree increments and set to zero.
Nov 19, 2009 | Makita 10" Compound Miter Saw LS1040
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Electric brake Fault. Blade Runs On.
some of my ls1040 repairs i replaced the switch and it seemed to correct the problem...
sometimes replacing the armature worked ...but like you did i always started with replacing the brushes
how does the condition of the armatures commutator look?
Jun 05, 2009 | Makita 10" Compound Miter Saw LS1040
Need to re assemble trigger of ls1040 mitre saw, is there any instructions
go to MAKITA TOOLS.COM under benchtop on the menu select miter saws and your model number once in there there is a menu showing instruction manual, parts assembly and you can geta full print out diagram of how it should go together
May 03, 2009 | Makita 10" Compound Miter Saw LS1040
Saws Logo
369 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
