Question about Cub Cadet Garden
Cub Cadet CC 760 33" walk behind, and I removed and cleaned the carburetor, but for heavens sake I cannot seem to figure out how to re-attach the link governer to the bracket control and carburetor.
  • 93 Answers
You will need to remove the carb first as the choke link must go on the carb first then attach the governor link to the carb along with the tension spring on the governor link then slide the choke link into the slot on the backside of the control bracket. The pic of the link you show is the choke link. I do this all the time but it's hard to write it down. Hope this will help you.
Posted on Jun 01, 2017
  • 1865 Answers
SOURCE: Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Posted on Jun 16, 2009
  • 78 Answers
SOURCE: How do you remove the front tire on Cub Cadet
Thats a plastic dust cap.Remove it very carefully so not to damage it. Then under the plastic cap will either be a Cotter pin or and E clip remove what is there and slid the tire and wheel off the spindle. These are a bear to break down and dismount and or remount. Unless you have a mini tire changer. I use my huge vise and a shaft the size of the spindle.I use motorcycle or bicycle tire irons. ITs a hassle believe me.
Posted on Oct 22, 2009
  • 2478 Answers
SOURCE: need wiring diagram for cub cadet lawn mower lt1045
Posted on Mar 15, 2012
SOURCE: Cub Cadet 2165 engine surges and eventually stalls
Replace the fuel cap!!! The problem is that hte fuel cap vents from it's underside. In so doing it sucks up all of the grass debris and dust that hte mower deck kicks up and the vents get clogged up. As the engine uses the gas, it builds up a vacuum in the tank and the gas can no longer flow from the tank to the engine.
Posted on May 27, 2012
  • 24 Answers
SOURCE: Noisey Cub Cadet mower
if you geting a humming sound try greasing the pullys and if this donot work, check the pullys for movement, you will feel the one that is bad.
Posted on Aug 01, 2012
Drive diagram for a cub cadet walk behind Model 999ES 12AE999T710
For a drive diagram, contact Cub Cadet directly.
Apr 17, 2017 | Cub Cadet Garden
What would be the expected engine life for a 2008 33" cub cadet walk behind?
Not able to tell, depends on how big the area is that you are mowing, how the engine is maintained etc.
Oct 22, 2016 | Cub Cadet Garden
Loose gear shifter
you may have a spring missing on the shifter replace t
Apr 12, 2013 | Mtd Cub Cadet 33 In 344 CC Wide Area Cut...
Removing lawnmower blades
check the belt that goes from each blade there is a timing mark on them
Aug 28, 2012 | Mtd Cub Cadet 33 In 344 CC Wide Area Cut...
Carburation Getting gas to the carburator but will not stay running without choke on
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 31, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Model SLT1554 PROBLEM: Engine cranks, runs for 1 second then dies. Cranks every time but dies immediately
Sounds like another carburetor blockage. Remove the carburetor and clean out all the orifices in the main jet. Also, check the float for leakage.
Sep 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
56 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
