Is there a product used for cleaning air conditioner fins covered with mineral deposits
  • Thomas Woodburn
    Thomas Woodburn May 07, 2017
    Not that you are aware of. I would leave it, it's not hurting anything and you only risk damaging the coil.
    Master:
  • 347 Answers
You can use any descaling spray, be sure not to bend the fins and rinse well with water. Be certain to shut unit off first.
Posted on May 07, 2017
  • Heating & Co... Master
  • 1,869 Answers
I'm certain you are referring to spots on your condensing coil. These are from someone putting coil cleaner on it and not rinsing it well enough. I see it everday and no they will not come off.
Testimonial: "thIt a white coating on the fims ere was no coil cleaner ever used"
CAN I USE CLEANER FOR SERVICE THE INDOOR AND OUT DOOR UNIT, CLEANER HAS CHEMICAL SENSITIVITY THIS WILL BE GOOD FOR UNIT OR NOT?
find an air conditioner service shop in your area as there are non caustic products available to use to clean the fins on the evaporator and condenser
places that sell compressors , driers, evaporators condensers to the air con trade will be the best place to go to
I use a product called viper E+ enzyme power which you spray into the fins of the units and it actively cleans for hours
it is a non rinsing cleaner made by refrigeration technologies part no rt350g
site www.refrigtech.com
not cheap but very effective
Feb 13, 2016 | LG LS-L1210CL Mini Split Air Conditioner
How do I clean the Rainmate?
Twist of stem from bottom, if excessive calcium or mineral deposits you can soak in vinegar. Keep hole in stem clean. Do not use harsh chemicals on any rainbow products it will compromise the materials. Vinegar should work.
Feb 03, 2016 | Rainbow Rainmate Air Purifier
Unclog personal humidifier doesn't work
If this is an ultrasonic humidifier, in the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 25, 2015 | Humidifiers
I cleaned my vicks 5100 series,but it still won't put out a vaper. the green light is on and there is air coming out but no vaper. i also changed the filter and waited still no vaper any hints to get...
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 25, 2015 | Vicks Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Slant fin doesnt turn on
Jun 23, 2014 | Slant Fin Humidifiers
Emerson air conditioner filter cover
if you want to clean the coil on it, you need to get a wire brush and gently brush the dust off. be very careful not to bend the metal fins shut. you could ruin the unit if you do so
Jun 30, 2013 | Heating & Cooling
PLEASE TELL ME WHAT DOES A MASTERCOOL CLEAN MACHINE PURGE PUMP DO?
From the ad below, it replaces old water with fresh. ------------------------------------------------------------------------- » HVACR» Air Conditioners» Evaporative Cooler Accessories Universal Cooler Cleaning SystemBrand: MastercoolModel: CM120ASKU: 47495 34252_300.jpg
$74.13
3 Business Day Shipping $7.91
No Longer Available Mastercool CM120A Universal Cooler Cleaning SystemTotal Ratings: 0
Average Rating: 0
Review this item transparent.gif Product Information Item Cleaning System Function Timer-actuated, Automatically Removes Mineral-laden, Dirty Water every Six Hours and Replaces with Fresh Water, Reduces Scale Deposits and Leaves Pads Cleaner, Saves Up to 70 Percentage of the Water Weight 3.10
  • Replacement Motors and Accessories
  • Universal Cooler Accessories
  • Cleaning System
  • Save up to 70% of the water used in bleed-off cleaning systems.
  • Timer-actuated drain system automatically removes mineral-laden, dirty water every six hours and replaces with fresh water.
  • Reduces scale deposits and leaves pads cleaner.
  • Uses: For residential size coolers only.
  • Note: Limited availability.
Universal Cooler Cleaning System, Clean Machine Pump Cooler Flushing Device for Residential Size Coolers Only
Apr 04, 2011 | Heating & Cooling
The airoswiss 7135 humidifier works fine. However, it leaves a fine gray film over everything, in every crevice, especially plastic products and stainless steel appliances. I contacted the company for...
You may have Hard water in your area (a lot of mineral content). This has happened to me before. You could try using distilled water or bottled water brought in from somewhere else. It is the mineral deposits that are causing the film on everything. I hope this helps.
Jan 28, 2011 | Heating & Cooling
Need to access inside of Carrier air conditioner.
After removing the cover and filter, you should be able to see the fins for cleaning. If there is styrofoam in front of the coil, it should not be there for proper operation.
Aug 20, 2009 | Carrier 52FE312-3 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
