Question about Fisher Washing Machines
I have a french door fisher paykel works well but no led condtrol l lighs on door
  • 242 Answers
Checck wiring at the top where it comes over the door top.
Posted on Sep 27, 2017
SOURCE: E249T Fisher and Paykel Beeps when door opened
Disconnect the Fridge for 5 mins. After that, should be ok.
Posted on Apr 12, 2009
  • 205 Answers
SOURCE: Our Fisher Paykel OS302 completly overheated
The thermostats have probably blown. There is a rebuild kit for this problem, it is not cheap nor is the labor to do it. Try shutting off the breaker for a few minutes... sometimes it will reset, but not heat. In any event you should have the new thermostat kit installed. F/P should at least be able to give you the tele. of a Tech., keep in mind that depending on where you live there are very few technicians that are certified to fix these.
Posted on Jul 21, 2009
  • 6784 Answers
SOURCE: Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
Posted on Dec 20, 2009
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
  • 88 Answers
SOURCE: Fisher & paykel fault "F1" is displayed on the top
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Posted on Jul 27, 2011
How do i take the bins out of the freezer? fisher and paykell product no 20717 model E372B.
Text, manuals and videos.
[PDF]Installation instructions and User guide - Fisher & Paykel Appliances
Never freeze liquids in glass containers. Liquid expands during freezing, which may cause the container to explode. ?. ?. Never freeze carbonated drinks. They may explode. ?. ?. Do not consume food if it is too cold. Food removed from the freezer compartment may be cold enough to cause damage when brought into ...
[PDF]Refrigerator & Freezer - Fisher & Paykel Appliances Food removed from the freezer compartment may be cold ... E372B. E381T. E402B. E411T. E415H. E406B. E413T. E440T. E442B. E521T. E522B. A inside height. 853 1255 1635 1255 1635 1475 1735 1465 1635 1735 1635 ..... The humidity lid seals the bins to provide a humid microclimate to extend storage times of fruits.
Page 41 of Fisher & Paykel Refrigerator E372B User Guide ... > ... > Fisher & Paykel Refrigerator Permanently fixed bins and trays (Freezer drawer models only). The freezer bins and trays in this model are permanently fixed. They cannot be removed from the. freezer compartment. To clean simply wipe with a soft, damp cloth. On vacation/holiday.. Turn the ice maker to OFF on the internal control panel (refer to page ...
Page 25 of Fisher & Paykel Refrigerator E372B User Guide ... > ... > Fisher & Paykel Refrigerator Remove all frozen food and wrap it in several layers of paper. Place food in the refrigerator. compartment or a cool environment e.g. insulated picnic bin. Switch the power off at the wall. The temperature control can remain at its normal setting. Remove the freezer baskets or shelves for ease of cleaning. Whilst defrosting ...
Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A ... Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins ...
Refrigerators - Removing & Replacing The Drawer on Vimeo
? 2:35 > Fisher & Paykel Technical > Videos
Jun 29, 2012 - Uploaded by Fisher & Paykel Technical
This video shows the proper method for removing and replacing the drawer on Fisher & Paykel ...
Ice Storage Bin - Fisher & Paykel ActiveSmart E372B Installation ... > ... > Installation instructions and user manual
Fisher & Paykel ActiveSmart E372B Manual Online: Ice Storage Bin. All models When going on vacation/holiday we recommend cleaning your ice bin and discarding...
[PDF]Fisher & Paykel RF522ADX5 519L French Door ... - Winning Appliances Note: non-Ice & Water models do not have an external water dispenser. Refrigerator French door and freezer drawer. Refrigerator door and freezer door .... 9. Installation instructions. Product dimensions (mm). E372B. RF372B. E402B. RF402B. E442B. RF442B. E522B. RF522B. A overall height of flat door product. 1620.
fisher & paykel e522b manual Products 1 - 20 of 23 - Shop with confidence on eBay! Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, ...
fisher and paykell E372B remove freezer bins Google Search
Feb 18, 2018 | Fisher Refrigerators
Could be a clogged drain line. In freezer just below the evaporator coil is a hole that drains to a pan usually can be cleared with hot water and a turkey baster
May 06, 2015 | Fisher & Paykel Paykel RF201ADX5 RF201ADX5...
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar
Extract From the fisher & paykel website user guide seems to be all about the handles.
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
Fridge is showing f24 fault and wrench symbol. No ice is being made and it peeps continually when door is open
Nov 16, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Ice maker not working. Fridge keeps beeping when opened
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Jan 31, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
F34 what does it mean
Call fisher and paykel directly, they will usually give you the answer and let you know if you need to call a technician out or if it is a quick fix that you can do. 1-888-936-7872 Good Luck, Appliance Specialists.
Jan 18, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
