Mita KM1525 error J10,J50
I have mita KM1525 code error J10 and J50 help me please
SOURCE: Mita error code
in mita DC.1856 what is solve the problem ,that code error is (C45)
Posted on Jan 20, 2009
  • 848 Answers
SOURCE: Mita Kyocera KM1535 with an error code. C710
C170-Toner sensor/Developer Error
check usual suspects Sensor, Wiring, Developer material, connectors.......
Posted on Feb 05, 2009
  • 66 Answers
SOURCE: c-4
The C-4 series errors point to a problem with the polygon motor in the laser unit (LSU)
Generally speaking it is not serviceable.
Yuo will have to contact your nearest service agent
Posted on Jul 09, 2009
bolinlamar
  • 157 Answers
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Posted on Sep 18, 2009
ganggawangsa
SOURCE: SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Posted on Nov 28, 2012
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Error core j10
The manual says you have a paper jam in Multi-Purpose Tray.
It is on page 7-10
Jun 16, 2014 | Kyocera Mita TASKalfa 180 Black Toner...
I Keep getting a j10 display when I try to print on the display
A J10 shows up if there is no feed from the upper paper tray. Check the operation of the paper feed clutch for the upper drawer.
Good luck,
Peter
Dec 18, 2013 | Kyocera Mita Mita Copier Toner Cartridge...
What does this error mean call service in kyocera copiers?
elle marche pas
elle signale une erreure est afiche code j50
a quoi signifi code j50
Feb 23, 2010 | Kyocera CS-2550 Black and White Copier
Fault code J50 & dark strip.
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
May 18, 2009 | Office Equipment & Supplies
Feb 05, 2009 | ASUS P5GZ-MX Motherboard
SYSTEM ERROR
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Mita error code
I think that stands for OPEN. Check to make sure that all the doors are closed. Right side, left side door, and also front door.
Hope this helps.
If you still have the OP message, then let me know and I will dig out my books and look it up.
Good luck.
Mac
Mar 12, 2008 | Office Equipment & Supplies
jasbo
jasbo
