Question about Refrigerators
Is it possible to fit new pipe inside door to water dispenser
  • 100 Answers
SOURCE: water dispensing problem
No there isn't another solenoid in the door but remember that the waterline is running through the freezer door so if your freezer is to cold or if the channel the waterline runs through in the door is running to close to the inside of the door(usually happens in produstion when they inject the foam in the door it moves the channel) it will freeze your waterline.
Posted on Nov 03, 2007
mikedurland
  • 481 Answers
SOURCE: water dispenser system
the dispenser in the freezer door has a small low temp heater surrounding the dispenser compartment to keep this from happening, and also to keep condensation from building up around the dispenser. this heater may have stopped working.
Posted on Jul 05, 2008
t0pc4t
  • 132 Answers
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Posted on Aug 15, 2008
SOURCE: Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Posted on Nov 09, 2008
  • 10 Answers
SOURCE: Leak in the left door (water dispenser)
ck container to rule out simple leak ck for cracks in container make sure lines are secure and free of breaks also part can be ordered. first ck all basics lines and conections in compartment
Posted on Aug 18, 2009
Coffee won't come out of the machine, tried cleaning out the tubes but that just made it worse
You need to advise the model .. but assuming its the CVA 40XX series ... the frist thing to check is the dispenser which has the two pipes comming out of the bottom. This can get coffee residue build up which usually causes 1 or both pipes to have reduced coffee flow. Indication that this is at fault are if the flow is uneven between the pipes or if coffee flows down the outside of dispenser. You can chck this pipework for blocages by openeing door and blowing air though the pipe extending on inside of door. The the dispenser is blocked you need to remove from rear of door and then clean out thoroughly in running water. If this pipework is not and
You need to advise the model .. but assuming its the CVA 40XX series ... here is what I would do;
1. First check is the coffee dispenser on front which has the two pipes coming out of the bottom. This can get coffee residue build up which usually causes one or both pipes to have reduced coffee flow. The indication that this is at fault is if the coffee flow is uneven between the pipes or if coffee flows down the outside of dispenser. You can also check the dispenser for blockages by opening door and blowing air though the pipe extending on inside of the door. The air should flow through easily. If the dispenser is blocked you need to remove from rear of door and then clean out thoroughly in running water.
2. Next check the pump and water path. The pump for the coffee is also used for producing hot water. So if the hot water is working normally then you can rule out the pump. If you not getting hot water then its likely to be the pump or a blockage in the flow through water heater.
3. If above OK then it's a fault with Brew Unit. Follow procedure to remove the brew unit, clean unit and test the air path through both pipes by blowing. Note: When you take out brew unit it not possible to access one of the pipes because its protected by a plastic shield. There is a manual procedure to manipulate the brew unit to expose this pipe so you can blow through it. However the likely cause is not a blockage in these two pipes but the stainless steel filter that the coffee must pass through. You will need an Allen key to remove the bolt holding this in place. Once removed you need to check all holes are free of blockage by inserting a very small wire in each hole. Alternately you can replace this part. If the filter is clogged then you should consider using a different type of coffee as some types coffees cause this problem and others do not.
I hope this helps. regards
Mar 24, 2014 | Miele Coffee System
How How do I fix my broken water line that goes in to the freezer door to the water dispenser?
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
Apr 24, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
Hello, lost water in the house, now when came back on, water dispensor has a slow drip... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't seem to stay...
If you take the bottom grill off the front of the appliance -1x Philips screw either side- under the freezer door you will see where the water pipe goes through the hinge. follow that pipe back towards the underneath of the machine and you should come across a push-fit connector.
The pipe leading through the freezer door from the connector, and blow down it, re-fit, press dispenser paddle to allow to flow. This stops the drip in 9/10 instances.
If not you may need to have someone check the water valve for slight blockage.
Jan 27, 2011 | Whirlpool Refrigerators
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
My water dispenser in my GE refrigerator does not dispense water. The same lever that dispenses water also dispenses water. I have checked the ice and water selenoids and they are working. The cooling coil...
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
Oct 05, 2009 | GE Refrigerators
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser inside fridge does not dispense water
Aug 15, 2008 | KitchenAid Architect KBRA20ERSS Bottom...
Water leaking from refrigerator...
You may have a small hole in the internal water pipe. Possibly from rubbing against the motor.
Take the end of the pipe comming from the back of the fridge (water inlet) and blow as hard as you can into it. If air passes through then you have a leak for sure.
Get a second set of hands to run along the pipe while you blow and you should be able to feel where the air is comming from.
Had this problem years ago with an Americana double door with ice dispenser.
Apr 13, 2008 | Kenmore 53092 / 53094 Side by Side...
Samsungrs21dcns water dispenser problem
just below the doors of the frig is a kick plate. remove the kick plate. on the left youll see a water line that goes into the freezer door. there is a connection for that hose just under the freezer. disconect the hose the press the water dispenser. if water comes out of the hose then the water line is frozen inside the door. you can use a hair dryer to warm up the dispener area both from the front and from the back, inside the freezer, it will take about 30 min to defrost. but, if you get no water from that hose then you need a new water valve. more than likely its frozen in the door. thats common on ge models
Nov 26, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
