Question about The Health & Beauty
My Kymco maxi xls beeps all the time when switched on I have charged the batteries but it still beeps. Also is there an easy way to lift the push/drive lever at the back I cannot move it.
  • 13 Answers
SOURCE: Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Posted on Feb 02, 2010
  • 177 Answers
SOURCE: have Invacare Auriga 4 scooter about 2yrs old Put
Hi. I have had a few scooters that have had this problem after sitting for a while. The brake lining is stuck to the body of the brake assembly. When the brake is energised by the controller, it can't release.
De-clutch the machine like you did, and try rocking the machine back and forth. If this doesn't work you might have to have a new brake assembly fitted.
The wheels turn in opposite directions, because the drive is through the differential unit in the rear axle. Even a car will do this if the driving axle is raised in the air.
I have also had a few cases of stuck motor brushes in these machines, but from your description, I would say it is the brake assembly.
Good luck. Neil.
Posted on Jun 14, 2010
Testimonial: "It was a frozen brake. I took the brake to pieces,a lot of little springs spacers indent springs and rollers jumped out. Cleaned all components and spent a few hours figuring it out for re assembly. Working fine now . Thanks for your prompt and accurate reply. PeterR"
  • 692 Answers
SOURCE: While driving scooter rear will sometimes shutter
Yep There are 3 possible problems 1. Make sure that the key is out of the lock before reinstalling the battery pack. 2. The controller is overheating. Let it rest 10-15 minutes to cool down if it happens again and 3. I think you are having a brake problem where the brake is not fully disengaging from the motor and causing excess drag on the motor.
You can remove the brake from the rear of the motor being careful not to break or pull the wires going to the brake. Tie the brake up away from the motor keeping the wires intact. Try driving the scooter and see if it still shutters. If it doesn't then you can use it like that but you will have no brake and if you use ramps it is dangerous. You can carefully remove the brake pad and give it a good cleaning along with the face of the motor where the brake pad rubs. Then reinstall all the parts and try your scooter again. The shuttering should stop and to excess overload of the motor should stop too. You could replace the brake by contacting Pride Mobility @1-800-800-8586 and talk with tech support to find out if you can just replace the brake assembly. Hope this helps you
Posted on Oct 01, 2010
wcdoc1953
  • 280 Answers
SOURCE: when I turn the key
The beep code will begin with 10 very fast beeps, followed by 5 slower beeps. The 5 slower beeps is your actual code. The beep code 5 is a brake fault.
The scooter may be in freewheel mode or there may be a short in the brake.
Make sure the scooter is in drive mode with the rear brake lever in the correct position. If that does not clear the fault you need to check the electromagnetic brake.
To check the brake you need a digital voltmeter. The brake should read 30 to 65 ohms when you read across the pins. You need to measure the resistance at each successive point on the harness because there are 5 connectors. While you are inspecting these plugs, check for corrosion, loose pins, broken wires, and pins not making good contact. Disassemble the front and rear halves of the scooter when you do this.
If all the resistance checks are good up to the controller plug for the brake, you have a bad controller. With that being said, I usually see a bad connection at the multiple points in-between. Sometimes the wires for the brake will melt at the connector at the controller.
Inspect these areas visually, removing the rear cover of the brake/motor/transaxle and the controller. An experienced tech should charge you under 1 hour labor for the diagnosis. You may be able to save some money by checking the obvious areas for unplugged or bad connections first.
The brake will cost about $250, the interface wiring and connectors about $50 and the controller is about $500. For this reason, you should invest in a good tech to diagnose the problem first, before proceeding with any hit and miss do it yourself repairs.
Including a second visit to install the new parts, labor cost should not exceed 2 hours total.
This is a very popular model so you should be able to find an experienced tech in your area.
Posted on Dec 23, 2010
Testimonial: "Awesome detailed info on how to fis/diagnose the problem."
HoverTech
  • 232 Answers
SOURCE: Battery fully charged chair levers engaged to
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Posted on Dec 27, 2010
2006 Kymco Xciting 500 I will not turn over
Hi, Dean before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
500 RI won start
Scooter Troubleshooting Scooter won start All about Scooters KYMCO XCITING 500 Service Manual
Kymco Parts Online Kymco Parts monster
https://www.kymcousa.com/admin/dealeronly/ownerman/onroad/Xciting250-500_pre2008.pdf
Apr 23, 2018 | 2006 Kymco Xciting 500 I
Kymco Midi XL slows down then speeds up. Battery ok
Hi, Kenneth and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
http://scooter.wikia.com/wiki/Tuning_a_carburetor
How To Fix Surging Carburetor with Taryl
KYMCO ForU Midi XLS Owner Manual
Kymco Mobility Scooter Parts Spares WheelieGoodMobility co uk
http://www.discountscooters.co.uk/user-manuals
Jan 13, 2017 | Kymco Motorcycles
Kymco xls foru. Why does green light flash 9 times, then pause?
hi Graham, okay assuming it got a PG Drive controller or a ds 90 dynamic controller fitted , 9 flashes means a internal fault ,,,check all of the connections to the controller including the brake and motor connection.. it 's can be a real frustrating fault..For example i had scooters working perfectly then one day 9 bleeps, after making sure of connections were good ,it worked once again..
Currently i 'm working on a ds 90 dynamic controller , it got a 9 bleep problem, dry joints on the controller board ...
Regards
Rob...
Aug 17, 2015 | Health & Beauty
2005 Kymco Bet and Win 250 no electrical power
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
Scooter Electrical Ignition Parts for KYMCO Bet Win eBay
Couple Of KYMCO Questions
http://www.scootermasters.com/manuals/People-250-Full-Manual.pdf
Kymco Scooter Parts ATVs Scooter Parts Performance Scooter Parts... http://www.scooterunderground.com/knowledge/manuals/pdf/B&W%20250%20Owner's%20Manual.pdf
Apr 03, 2015 | 2005 Kymco Bet and Win
Hello i have a kymco xl mobility scooter which has developed a fault flashing green light.2 flashes pause 2 flashes pause and so on.i haven't got a owners manual and trying to find one on line is...
Hi , is it the Midi or Maxi XL model ? PG Controller (normally a silver colour ) has the following as the listed fault
There is a bad connection to the motor and the controller
If 's it a Rhino controller normally a blue colour ,
The battery is completely empty. The scooter does not drive.
• Recharge the battery immediately.
If the scooter is left off for a few minutes, the battery may recover enough
to allow driving again for a short time. However, driving on an empty
battery may cause damage to the battery.
Regards
www.gewizrepairs.co.uk
Oct 23, 2013 | Electric Mobility Health & Beauty
Where are the fuses for my kymco maxi mobility scooter
inside the control panel maybe and two inline fuses near the batterys
Oct 11, 2013 | Kymco Maxi XL Mobility Scooter
Kymco midi foru,less than 6 months old batteries will not charge.
This will be due to the batteries being left uncharged for a long period of time. Should ideally be charged once a fortnight for at least 12 hours if the scooter is not used for any period of time. Unfortunately, the only real solution is new batteries.
Feb 26, 2010 | Health & Beauty
Health & Beauty Logo
46 people viewed this question
Top The Health & Beauty Experts
trinatiodel
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
