Question about Dell NVIDIA GeForce 8600M GT,, Video Card
Call of duty 4 demands new driver for vga
Call of duty 4 demands upgraded driver .how this prblem can be sloved?my card is Nvidia 8600M GT
  • 31 Answers
Test your system requirements here dose it match?
http://www.yougamers.com/news/12705_call_of_duty_4_system_requirements_revealed/
Posted on Jul 25, 2009
Compaq sr5010nx
>Delete the old Nvidia card drivers off your computer.
>Install the ATI video card drivers (you probably did this, but....)
>You may have to disable the integrated video on the motherboard (if you have it) in the BIOS setup screen.
>Make sure the new card is seated properly, take it out and reinstall it. This is one of the most common problems.
>Make sure the VGA or DVI pins in the monitor video cable are not bent or damaged. Another very common problem.
>Swap monitor with a different one; if you get video your monitor is bad or there are some settings need changing.
>Take the video card back, it may be bad.
Apr 11, 2014 | Computers & Internet
Graphic card for Acer aspire
One of the best ones is the ATi Mobility Radeon HD 3650. The best NVIDIA one there is the NVIDIA GeForce 8600M GT. But the ATi GPU is better.
You will probably need to get a new card fitted by Acer or a named specialist.
Mar 05, 2014 | Acer Aspire 7720-6794 Notebook
Change graphics card vostro 1710
Some laptops do have a graphics card that is mounted to the motherboard, with it's gold plated contact pins.
The pins slide into an expansion slot on a circuit board, that mounts to the motherboard.
Removable, therefore deemed may be upgradable.
Most however are like Chris stated, and are mounted to the motherboard with a BGA surface mount.
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red ->
Take a few minutes to view the IR 650 demo video. (5 minutes)
Shows you the IR 650 BGA Rework Station at work, but more importantly shows you the BGA surface mount; Solder Balls, and Copper Pads.
http://en.wikipedia.org/wiki/Ball_Grid_Array
IF, your Dell uses Integrated Graphics, the motherboard chipset is an Intel GM965 chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_mobile_chipsets
Intel GMA X3100 integrated graphics.
http://en.wikipedia.org/wiki/Intel_GMA#GMA_X3100
Means the G.P.U. is integrated in the Intel GM965 motherboard chipset.
Nope. No upgrading of that baby.
IF, your motherboard chipset is an Intel PM965 chipset, it uses Discreet Graphics through a PCI Express bus,
Means the laptop comes with an Nvidia GeForce 8600M GT graphics chipset,
http://www.dell.com/us/en/bpi/notebooks/vostronb_1710/pd.aspx?refid=vostronb_1710&s=bpi
Here we can see the Dell Vostro 1700 series of Notebook PC's, uses a separate graphics (Video) card, (IF your laptop came with this option)
http://www.ebay.com/itm/Dell-DY445-VOSTRO-1700-INSPIRON-1720-nVidia-GeForce-8600M-GT-Video-Card-256Mb-/120955693339?pt=PCC_Video_TV_Cards&hash=item1c2985691b
The green circuit board of the Nvidia GeForce 8600M, you can barely see.
The aluminum metal plate on top of it, is attached to the copper Cooling Tube, then to the finned rectangular Heatsink.
[Heat is drawn from the graphics chipset {GPU} on the graphics card, to the large aluminum metal plate. The plate absorbs the heat, then transfers the heat to the copper Cooling Tube.
The Cooling Tube is a slightly flattened copper pipe, sealed on both ends, and filled with Nitrogen gas.
The Cooling Tube absorbs the heat from the plate, then transfers the heat up to the finned rectangular Heatsink.
The finned Heatsink absorbs the heat, then radiates it away with it's thin fins. Air flow from the Fan Assembly, helps carry away heat from the fins of the finned Heatsink ]
This is what the Nvidia GeForce 8600M looks like, not attached to the cooling assembly,
http://www.ebay.com/itm/ASUS-NVIDIA-GeForce-8600M-GT-8600mgt-512-MB-512M-DDR2-MXM-II-Graphic-Card-f-F8SV-/330701665242?pt=PCC_Video_TV_Cards&hash=item4cff5af3da
You can see plainly that this is a graphics/video card.
Four mounting holes, and gold plated contact pins on the bottom.
The actual term is graphics ADAPTER card. The Brownish/Red square you see in the middle/bottom, is the graphics chipset.
[ The actual G.P.U. or Graphics Processing Unit, is the black chipset in the middle of that brownish/red square, has Nvidia in white on it, and white characters on the bottom -
***-***-XX.
X's used because I can't read it.
The brownish/red square around the GPU is a small circuit board.
ALL GPU's have to have a small circuit board, in order to mount to the motherboard, or a graphics adapter card. Also for electrically connecting the GPU to a motherboard, or graphics adapter card.
GPU,
http://en.wikipedia.org/wiki/GPU ]
In conclusion;
1) Depends on what Intel motherboard chipset you have, right off the bat.
Intel GM965 = No
Intel PM965 = Maybe
2) Intel PM965? Then your laptop should have the above Nvidia GeForce 8600M GT, with graphics adapter card, and cooling assembly.
2A) Does that mean you can change the GeForce 8600M GT?
Maybe. You need a BGA Rework machine, and better Nvidia GeForce graphics chipset. You're talking Ka-Ching here. $$$$$$$$$$
Probably have to stay within the same Fabrication Technology in nm.
(nm = NanoMeter. 1 Billionth of a Meter)
The 8600M GT is 80nm fab technology.
So is the 8700M GT.
When you get to the 8800M GTS, it changes to 65nm.
That's the architectural size. Doesn't state all the technological features that changed with it. (80nm to 65nm)
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_8M_.288xxxM.29_series
Means your BIOS program probably won't handle it, and doubt there is a BIOS upgrade for it.
3) Better graphics adapter card, and graphics chipset?
Again, that IMHO would only be an Nvidia GeForce 8700M GT, and NOT worth the trouble, believe me.
So that's it? No chance of upgrading your graphics? No, not so.
More information in an added Comment.
Regards,
joecoolvette
Aug 15, 2012 | Dell Vostro 1710 Laptop
Help I find drivers nVIDIA_8600M_GT for windows Xp
Hey there, You can download the 32-bit driver here: http://www.nvidia.com/object/notebook-winxp-266.58-whql-driver.html
if you have 64-bit version of XP, then you can download the 64-bit driver here: http://www.nvidia.com/object/notebook-winxp-x64-266.58-whql-driver.html
Feb 22, 2011 | Computers & Internet
No solution found. I wonder if the solution exists. Anyway, here is the pb. no drivers for the following running on an hp pavilion dv9858 under Windows Xp i-Sound card: Intel 82801HBM ICH8M - High...
Follow the instructions at the bottom of this page for the sound card:
http://www.howtogeek.com/forum/topic/help-needed-to-find-device-drivers-for-win-xp?replies=8
for the video card: http://www.opendrivers.com/freedownload/284952/nvidia-geforce-8700m-gt-8600m-gt-8400m-gs-8400m-g-forceware-driver-176.37-windows-xp-x32-download.html
Apr 04, 2009 | HP Pavilion dv9700t Notebook PC
I need update for my vga card
it is the game defect. although u may upgrade the drivers from nivida's web site.
Nov 20, 2008 | MSI nVIDIA GeForce 6800 GT PCI-E 256MB...
HP dv9825 laptop
this a built in card it cannot be upgraded, els u could use a PCMCI card.
Nov 03, 2008 | Computers & Internet
I have a e-GeF0rce 8600 GTS. My computer sees a NVIDIA GeForce 6150SE N FORCE 430.0. iS THIS A PROBLEM
Hello Baldarchi,
This is normal and how ever uninstall the current driver and install latest driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Nvidea%20video%20driver.exe
The above driver supports:
[DEV_0098] NVIDIA GeForce Go 7800 [DEV_0099] NVIDIA GeForce Go 7800 GTX [DEV_00C8] NVIDIA GeForce Go 6800 [DEV_00C9] NVIDIA GeForce Go 6800 Ultra [DEV_00CC] NVIDIA Quadro FX Go1400 [DEV_0144] NVIDIA GeForce Go 6600 [DEV_0146] NVIDIA GeForce Go 6600 TE/6200 TE [DEV_0148] NVIDIA GeForce Go 6600 [DEV_0149] NVIDIA GeForce Go 6600 GT [DEV_0164] NVIDIA GeForce Go 6200 [DEV_0166] NVIDIA GeForce Go 6400 [DEV_0167] NVIDIA GeForce Go 6200 [DEV_0168] NVIDIA GeForce Go 6400 [DEV_01D4] NVIDIA GeForce Go 7350 [DEV_01D6] NVIDIA GeForce Go 7200 [DEV_01D7] NVIDIA GeForce Go 7300 [DEV_01D8&SUBSYS_81E6104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81EF104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81FD104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_8205104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_820F104D] NVIDIA GeForce Go 7400 [DEV_01D8] NVIDIA GeForce Go 7400 [DEV_01DA] NVIDIA Quadro NVS 110M [DEV_01DB] NVIDIA Quadro NVS 120M [DEV_01DC] NVIDIA Quadro FX 350M [DEV_0244] NVIDIA GeForce Go 6150 [DEV_0247] NVIDIA GeForce Go 6100 [DEV_0297] NVIDIA GeForce Go 7950 GTX [DEV_0298] NVIDIA GeForce Go 7900 GS [DEV_0299&SUBSYS_309F103C] NVIDIA Quadro NVS 510M [DEV_0299] NVIDIA GeForce Go 7900 GTX [DEV_029A] NVIDIA Quadro FX 2500M [DEV_029B&SUBSYS_309F103C] NVIDIA Quadro FX 1500M [DEV_029B] NVIDIA Quadro FX 1500M [DEV_029D] NVIDIA Quadro FX 3500 [DEV_0397] NVIDIA GeForce Go 7700 [DEV_0398&SUBSYS_81EF104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_8205104D] NVIDIA GeForce Go 7600 [DEV_0398] NVIDIA GeForce Go 7600 [DEV_0399&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 GT [DEV_0399&SUBSYS_8205104D] NVIDIA GeForce Go 7600 GT [DEV_0399] NVIDIA GeForce Go 7600 GT [DEV_039A] NVIDIA Quadro NVS 300M [DEV_039B] NVIDIA GeForce Go 7900 SE [DEV_0407&SUBSYS_01F11028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_01F21028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02281028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02291028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_022E1028] NVIDIA GeForce 8600M GT [DEV_0407] NVIDIA GeForce 8600M GT [DEV_0408] NVIDIA GeForce 8600M GTS [DEV_0409&SUBSYS_019B1028] NVIDIA GeForce 8700M GT [DEV_0409&SUBSYS_019C1028] NVIDIA GeForce 8700M GT [DEV_0409] NVIDIA GeForce 8700M GT [DEV_040B&SUBSYS_30C3103C] NVIDIA Quadro NVS 320M [DEV_040B] NVIDIA Quadro NVS 320M [DEV_040C&SUBSYS_20D917AA] NVIDIA Quadro FX 570M [DEV_040C&SUBSYS_30C5103C] NVIDIA Quadro FX 570M [DEV_040C] NVIDIA Quadro FX 570M [DEV_040D&SUBSYS_019B1028] NVIDIA Quadro FX 1600M [DEV_040D&SUBSYS_30C3103C] NVIDIA Quadro FX 1600M [DEV_040D] NVIDIA Quadro FX 1600M [DEV_0425] NVIDIA GeForce 8600M GS [DEV_0426] NVIDIA GeForce 8400M GT [DEV_0427&SUBSYS_01F11028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F21028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F31028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02091028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02271028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02281028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02291028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_022E1028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_9008104D] NVIDIA GeForce 8400M GS [DEV_0427] NVIDIA GeForce 8400M GS [DEV_0428&SUBSYS_9008104D] NVIDIA GeForce 8400M G [DEV_0428] NVIDIA GeForce 8400M G [DEV_0429&SUBSYS_01FE1028] NVIDIA Quadro NVS 140M [DEV_0429&SUBSYS_20D817AA] NVIDIA Quadro NVS 140M [DEV_0429] NVIDIA Quadro NVS 140M [DEV_042A] NVIDIA Quadro NVS 130M [DEV_042B&SUBSYS_01F91028] NVIDIA Quadro NVS 135M [DEV_042B&SUBSYS_01FE1028] NVIDIA Quadro NVS 135M [DEV_042B] NVIDIA Quadro NVS 135M [DEV_042D&SUBSYS_01FF1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024A1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024B1028] NVIDIA Quadro FX 360M [DEV_042D] NVIDIA Quadro FX 360M [DEV_0530] NVIDIA GeForce 7190M / nForce 650M [DEV_0531] NVIDIA GeForce 7150M / nForce 630M [DEV_0532] NVIDIA MCP67M [DEV_0533] NVIDIA GeForce 7000M / nForce 610M [DEV_053F] NVIDIA MCP67M
Sep 12, 2008 | Computers & Internet
8600M Gt
hi my name is wesley. when it asks you to upgrade it it should have a button asking if you want to upgrade or download when it says that witch should take you to the download site.
Jul 19, 2008 | Nvidia 64MB GeForce3 AGP Video Card with...
Dell NVIDIA GeForce 8600M GT,,  Video Card Logo
175 people viewed this question
Alun Cox
