Question about Refrigerators
Operater manual for electronic ignition camper fridge
My camper water heater with electronic ignition lights for a short few second burst 3 times and then times out due to heater switch inside camper..why
Sounds like it may be a dirty flame sensor. It can be gently cleaned with steel wool or scotch bright pad (not emery or sand paper). Its a small rod that sits in the flame. I believe it is part of the spark ignition assembly on your model. Only open your burner compartment though if your are certain you have the skills (and perhaps gaskets etc) to reassemble it safely.
God bless
Aug 06, 2014 | RTO Atwood Water Heater - 6 Gal LP
No spark
Did you check the coil wire itself? A break in it will be hard to see. Get another one, or temporarily borrow one from one of your plugs, just for long enough to see if it gets spark. If it does, you know the rest, I'm sure. I'd check all plugs and be sure that little wire under the cap is on the tab. I've had a breaker plate wire fall of on me once, took forever to figure that one out. Even an electronic ignition needs to be grounded at the distributor. You've probably just got a connection issue.
Let us know if there's still a problem.
Apr 20, 2014 | Lite On Spark Plug Lite Green LED
Dometic RM2652. The fridge will not work when it is plugged into AC.
Unplug the fridge. Remove the cover from the circuit board, unplug the 2 wires going to the heat element and do an Ohms reading should be 35-45 Ohms. If the Ohms is good then you need a circuit board as long as you have checked the 110 volt fuse on the circuit board.
Apr 30, 2012 | Dometic RM2652 Refrigerator
Water Heater electronic ignition to work???
Here's a link to operators manual. You can download PDF file as well and print for later use if you wish.
Apr 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The fridge will not turn on. Should I be turning on the 100 switch, even if the camper is plugged in, and the lights are working?
Do you mean the 110VAC switch? Unless you are running the fridge on propane, it will need something to power it and if the camper is attached to power the fridge can be run on AC.
Sep 01, 2009 | Dometic WA3210 Compact Refrigerator
Fridge in VW camper van
Jul 26, 2009 | Refrigerators
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Camper fridge ignites and runs on gas then fails
I beleive the thermocouple is faulty, this allows gas to flow once the flame is lit, but will also close the valve if faulty. Rateme
Mar 11, 2009 | Electrolux Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
