Question about Measuring Tools & Sensors
I need to know the head torque spec and valve clearance on briggs&stratton#126412-0138-e1
  • 376 Answers
SOURCE: what is the valve clearance on a briggs &
.003-.005 intake, .005-.007 exhaust for single cylinder OHV
Posted on Jun 14, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
mickey813
  • 472 Answers
SOURCE: what is torque specifications for briggs and
WELL THAY ALL ARE DIFFRENT SO TELL ME WHAT PART DO YOU NEED IT FOR
Posted on Sep 30, 2009
mickey813
  • 472 Answers
SOURCE: I cant find torque specs for a briggs and stratton
WHAT SPECS DO YOU WANT WHAT PART ARE YOU CHANGING
Posted on Oct 02, 2009
mickey813
  • 472 Answers
SOURCE: Proper procedure to adjust valves on Briggs and
YOU HAVE TO REMOVE THE PLUG AND ROTATE THE MOTER TO T D C THEN TUR IT HALF PAST THEN CK THE VAVEL CLARENC ARE YOU SURE THIS IS THE PROBLEM TELL ME WHAT ITS DO ING SO I CAN MAKE SURE THATS THE PROBLEM LET ME KNOW
Posted on Oct 07, 2009
Need a repair manual .pdf for a Briggs and Stratton Model 311707 Type 0132-E1 engine
H.A., Check the attached links,instruction and guides for Briggs and Stratton, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My 311707 0132 E1 Model Overview from PartSelect com
http://www.smallenginesuppliers.com/html/engine-specs/briggs_vertical_shaft_engines/276781SingleCylinderOHV.pdf FAQ Small Engine Specifications Briggs Stratton Specs
Briggs Stratton Small Engine Specifications
Jul 01, 2016 | Measuring Tools & Sensors
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
Does anyone know the head torque specs and tightening sequence (if necessary) for B&S 42A707 Type 2238 E1 17 HP? Thanks.
briggs has service manuals available on their website... take those numbers and search... and yes. they have a sequence and a torque spec. which is 160 inch pounds
Oct 25, 2014 | Briggs & Stratton Garden
WHERE TO FIND briggs stratton repair manuals
This is not a repair manual, but this link will give you all your torque and clearance specs needed for complete rebuild.
Hope this helps.
Aug 25, 2014 | Garden
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Measuring Tools & Sensors Logo
124 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
