Question about Music
How can I remove keylock from my telefunken tledd-32fhdb television
Paul nagel
Hello...i have a black gibson les paul custom. Serial number 00117886. what year is it and would this be considered a black beauty? any idea of value too?
The term 'Black Beauty' has been well overused by now. It was originally the 1957 black Les Paul Custom model, but by now is any black Les Paul Custom. In addition Gibson themselves are cashing in by doing reissues, finished to look older.
So if it is a black Les Paul Custom, then yes, it is a Black Beauty, according to someone somewhere. On top of that, Gibson has reused serial numbers, in different years for different models.
If the serial number is stamped on the headstock with 'Made In USA' the guitar was made at the Kalamazoo or Nashville Plant, in 1976.
Those guitars are worth US$3000-4000 depending on condition.
Otherwise it was made at the Nashville Plant, TN, on January 11th, 2007.
Those newer reissue guitars sell for similar prices.
Feb 24, 2017 | Gibson Music
Is there a battery in a epiphone les paul standard
As stock, the Epiphone Les Paul Standard does not use a battery.
Aug 02, 2012 | Epiphone Les Paul Standard
I have just purchased a les paul ultra 2. The nano pick up does not work without increasing the gain. I thought the volume control on the front controlled the nano pick up and the gain was for just that. I...
You need to adjust the controls for the nano on the control cavity plate on the back of the guitar the way you want them first. Here is a link to a simplified explanation: A better explanation should be in the manual but I don't think they did as good of a job as they should have.
Oct 17, 2010 | Epiphone Les Paul 100 Electric Guitar
I am thinking of buying an Epiphone Les Paul serial number U99040169. How much is it worth?
Try this link: Hope this helps.
Jul 02, 2010 | Epiphone Les Paul Studio Electric Guitar
Fix the wiring in a epi lp100
Its basic diagram #2.....but a twin pickup les paul is a twin pickup les paul!
May 06, 2010 | Epiphone Les Paul 100 Electric Guitar
How do i choice to buy a custom epiphone les paul
If you are on a limited budget then get a standard Epiphone Les Paul. The Custom is not much better. If you have a little more to spend then I recommend getting a new or used Gibson Les Paul Studio.
Narrowing down which guitar to buy is completely opinion-based. You need to try multiple guitars to find one you like best since they all feel a little different.
Oct 01, 2009 | Epiphone Les Paul 100 Electric Guitar
Output jack on a Epiphone Les Paul came out and I ned a schematic
google your problem. i have found scematics on everything. i'm currenly changing out the pickups on my les paul, and saw the diagram on your soldering setup. i've done these myself. i was a little worried at first, but it turned out to be pretty easy. good luck, scott
Apr 07, 2009 | Epiphone Les Paul Studio Electric Guitar
Getting Static noise when plugged in to amp
This is a very common problem that I have repaired for many friends. Sometimes the guitar jack becomes loose and gets rotated to the point where the wire breaks and/or touches the cord plug when it's inserted into the jack. You need to remove the access plate/panel at the back of the guitar body and see if the wire is broke or twisted. You may only have to loosen the jack retaining nut and rotate the jack to get the twist out or you may have to remove the jack and resolder the wire back in place. If its broke make sure to solder back on the proper terminal--the one with solder already on it and not the one that the cord plug touches when its inserted. Retighten the jack nut by firmly holding the jack from access side so it doesn't rotate again and cause that undesirable STATIC sound. Hope this helps.
Dec 08, 2008 | Epiphone Les Paul Studio Electric Guitar
Music Logo
23 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
