Question about Magnavox Audio Players & Recorders
What is the beat cut switches for on my magnavox AW7050 boombox for?
Cd boombox and headphones
HelloWhen a headphone pin is inserted into a headphone socket, it is normal that the internal speaker of the system will cut OFF. It is normal operation, and not a fault. The speakers of such portable sets are wired such that it should cut OFF when headphone pin is inserted into it. We inserts headphone pin to hear the reception or CD music personally. So there is no need for an output from its speakers. Isn't it?
Dec 18, 2011 | Disney Memorex Portable CD Boombox...
When i buy sony cassette tape, it records good on just one side of a cassette. the other side rather outside mic or inside off radio is very low almost impossible to hear up close.
Hello
Check and clean the mechanism parts of your casette player mechanism. Look whether there is dirt accumulated on the capstan shaft and pintch rollar of the mechanism. This is the main cause of tape slip and irregular output from it. OK.
Sep 22, 2011 | Philips Magnavox MCS225 17...
CD player freezes on certain tracks. My only way to stop it is to push the advance arrow to go to the next track It seems to happen on every CD I play.
try to clean your optical lens, by a cotton badge and put some oil on moving parts. if ended you need to replace optical assembly. or try to re align potentiometer that control the focus of the lens.
Apr 10, 2010 | Philips Magnavox MCS225 17...
RCA Boombox model # RCD158A - will not record
Hiya 2 possibles here:
1 - At the back of the cassette, there are 2 "tags", one on the left, one on the right. if those tags are broken out, it wont record. You put a piece of tape over the holes, that wll do
2 - If thats OK (dont know the beat box myself) but often you need to press play and record together
Hope one of those work!
Jul 26, 2009 | RCA RCD158 Boombox
Top Magnavox Audio Players & Recorders Experts
Jay Plesset
gbob59
Are you a Magnavox Audio Player and Recorder Expert? Answer questions, earn points and help others
