My Senseo coffee maker machine will not open. It has been drained and switched off for several days but is still locked solid. Help please
SOURCE: Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Posted on Jan 06, 2009
SOURCE: lid is stuck shut on my senseo
I just had this same problem. The seal is stuck and might have coffee jammed in it. I unplugged it. Then I pushed down on the lid and pulled up at the same time. It opened for me. I hope this helps.
Posted on Jan 21, 2009
  • 17 Answers
SOURCE: one coffee cup button switch not wotking properly after 6 months
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.
if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Posted on Feb 03, 2009
SOURCE: stuck senseo maker
The locks shut due to a pressure build up in the pod chamber usually caused by a blocked filter in the centre of the pod holder.
The only way to open the unit is to releive the pressure. The pressure will normally reduce over time, the duration being determined by the pressure build up, condition of pod seals and the strength of the blockage.
A quick DIY solution: (small cable tie and screwdriver required)
Un plug the unit from the mains:
Remove the water container and prise open the rear snap fit panel of the unit carefully using a screwdriver to expose the internal workings, the overflow pipe at the top of the cover must be disconnected to gain enough access to work on the unit.
.The small metal boiler in the centre of the unit is used to heat the water for the machine, if the boiler is still hot allow it to cool down sufficiently for work to commence.
The exit pipe at the top of the boiler feeds directly to the pod chamber, if you squeeze this pipe you will feel that it is under pressure. Cut the cable tie connecting the pipe to the boiler (be careful, dont cut the pipe) and remove the pipe to release the pressure, a small ammount of water will be released during the procedure. The lid should open.
Reconnect the pipe to the boiler replace the cable tie, refit the rear cover making sure to push the overflow pipe back on before you snap the cover shut.
Remove the pod holder and clear the blockage blow through the holder in the reverse direction to ensure the filter is clear.
Replace the pod holder and pour a small amount of water on to it. The water should exit through the delivery spouts if the path is clear.
JOB Done.
Posted on Feb 23, 2009
  • 34 Answers
SOURCE: how do you take apart a senseo coffee maker
yes!! It would be with difficulty.. I suggest you should replace it with a new one. Hope this link can help you with your concern.
http://www.coffeemakerwizard.com/
Posted on Feb 05, 2010
Machine not in use for a long period of time. Concerned with remaining water inside machine
Water stays in it, true, putting the senseo upside-down for a longer period of time, might drain the boiler. Let's hope it did not freeze up.
try following: switch on Senseo, and push both One + Two cups buttons, this will drain the boiler.
Jan 26, 2014 | Philips Senseo HD-7810 Coffee Maker
Turned machine on this am,power light came on for a few secs,then went off...cannot turn on use my senseo every day...please help
Try another wall socket, and fumble a little with the wire - it may have been damaged. If you can notice a relation between moving the wire and the Senseo switching on and off, the wire should be replaced.
Nov 13, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo hd7810, The locking/unlocking latch on the
The product is still in production, so that should not be the problem. Question is whether the handle is a spare part.
G
Mar 02, 2009 | Philips Senseo HD-7810 Coffee Maker
One coffee cup button switch not wotking properly after 6 months
Jan 24, 2009 | Philips Senseo HD-7810 Coffee Maker
Wont boil
Its no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Dec 21, 2008 | Philips Senseo HD-7810 Coffee Maker
Replacement seals for Senseo Coffee machine
If no good,
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo stuck after using coffee pods that have "milk" built in....5 days later
I had the same problem. I waited for a while as the instruction says but didn't open. But, I got it open!!! by turning and slightly pulling a small plug behind the water tank on the backside. (remove the water tank then you'll see the little plug. see attached photos) I think it will let air in and vacuum seal get released. After it opened, I gently turned the plug back and push it in as it was. Now, it is running perfectly again. I just had a great coffee. :-)
58c3f6de-9c9e-437e-b419-0533bdf0a452.jpg562b78da-5cdf-43fe-afb9-546e2ba78530.jpgb5d600f7-721a-4b74-a954-ef849424bf28.jpg
May 14, 2008 | Philips Senseo HD-7810 Coffee Maker
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
