Question about Hotpoint Washing Machines
Hotpoint Futura HF8B593 keeps leaving a dirty residue, brown slimy in consistency over the washing. The machine isn't overloaded, I.e. Just duvet cover in there. Help I have had enough
    New Friend:
  • 3 Answers
Wash out tub with bleach,fill a cup of of bleach and let washer run thru all cycles.After it shuts off ,leave door open to avoid mold from growing
Posted on May 08, 2017
What is meant by a duvet?
A duvet is a type of bed covering that contains a bag filled with down, feathers or synthetic material. It is protected with a cover called as Duvet cover. You can remove this cover to give an absolute new look to your bed. Feather used in duvet are either made up of duck or geese feathers. I would recommend you to use Hungarian Goose Down Duvet as I have used this product personally. You will love the comfort it proves as the geese feather are much more softer than the duck feathers.
Feb 08, 2018 | Washing Machines
Where is the dirt trap on the Hotpoint WMD 740?
Run the washing machine with a cleaner compound like http://www.target.com/p/tide-high-efficiency-washing-machine-cleaner-5-count/-/A-14230069
Also the pump can be cleaned by undoing the tap at the bottom front of the washer. First make sure the drain tube has been pulled out to empty residual water in a container. Then unscrew the tap and filter to clear any dirt and items stuck in it.
Check the manual at this site.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMD740PUKRE_19509388200.pdf
Sep 16, 2014 | Hotpoint Washing Machines
My whirlpool GS6NBEXR refrigerator ice cube maker leaves slimey, flaky residue at the bottom of my glass. What can I do?
Diana, if I understand you ok, the ice you put in the glass leaves slimy residue. So that slimy stuff has to be in the ice cube. Well remove the the ice maker unit and thoroughly clean this ice holder and throw away the ice cubes in the kitchen sink and see if leaves slimy stuff. As for slimy stuff, while the unit is out, check any leaks etc. BTW any smell?
Jan 06, 2014 | Whirlpool GS6NBEXR Side by Side...
Can you help? we have a hotpoint aquirius 1100 waher, the drum seal seems to keep getting dirty, wife keeps machine spotless and allways cleans seal, but constantly gets brown scum going onto washing and...
hi my trick is .................... WHITE VINAGER ...YES VINAGER ... right get 5 ltrs of white not brown or your cloths will STINK :))) now wip some around seal .... tip 2 ltrs into drum ...and rest into powder capartment .... leave for 5 min ...then put on boil wash ...DONT PUT ANY THING ELS IN ..IE CLOTHS OR POWDER.. it normally gose .. wash through x2 times with powder ect b4 any cloths go in . bsc appliances bristol 07779933829 postal service too.
Feb 26, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Sometimes it spins sometimes it doesn't had a problem this morning with a king size quilt, it came out soaking so I tried to spin it again & its still wet, I put in another load & then it...
Duvets/quilts are very heavy when wet, causing a very unbalanced load. If the machine could spin such a large uncentred (UK spelling!) mass it would shake itself to pieces, so all modern domestic washing machines have unbalanced load detection systems. In use these systems will vary the drum rotation to try and get the load evenly distributed before going into full spin, but if they can't then no spin occurs.
Very few domestic washing machines can take a duvet or quilt (certainly no front loader which I'm aware of, and only a few top loaders), and those which can fit them in are usually overloaded. There's nothing wrong with your machine, you just need to use a commercial launderette machine to wash and spin your duvet/quilts in future.
Feb 16, 2011 | Washing Machines
The rubber on the inside front of the washer ("the door boot") gets very dirty, slimy and is all stained. As I pulled the rubber back to clean it, it was digusting ! It is starting to leave marks on the...
at this point and time the best thing to do is replace the door seal.and then make sure after each wash cycle you dry out or leave the door open somewhat in order to help keep it dry and clean
Jan 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Slimy - stinky - brown residue on my clothes after wash
Check the water inlet valve/ Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are free of rust or debris. The small screens tend to get rusty due to elements in the water and can cause the type situation you describe. I will attach a photo for reference. Hope this helped and best wishes.
Sep 04, 2009 | Washing Machines
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
