Question about Vacuums
New belts for cricut explore air
Where to purchase belt
Why isnt the beater bar turning on my shark. The belt is intact
More then likely, the belt is just worn out and slipping on the drive shaft. (I've encountered this problem) replace with a new belt.
Mar 04, 2015 | Shark Vacuums
Where is belt for ul70120 found
Hi there! The belt for the Uh70120 can be purchased from Hoover.com directly or from an authorized service center. This unit takes belt number 562932001. Below you will find a link where you may go to purchase the belt, as well as a link to our service center locator.
http://bit.ly/1lzmUv1
Service Center Locator
Hope this helps!
Aug 12, 2014 | Hoover Vacuums
My dyson dc33 beater bar won't turn
There are belts in the clutch, which is the lever you can move to adjust the vacuum from floor to tools. The belts become stretched and need to be replaced. You can purchase just the belts or purchase the clutch assembly with the belts installed. There is also a belt change tool that makes the job much easier to install because the new belts will be much tighter than the old belts. The parts are available from thatvacguy.com.
Jul 10, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
How do u repair a broken rubber belt that helps spin the brush?
Hi, it's Cindy from Crucial Vacuum.
Unfortunately there is no way to fix a broken belt. The only way to repair the vacuum is to purchase a new belt.
You can purchase your replacement belts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-elite-rewind-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 27, 2014 | Hoover U5507900 Elite Rewind Bagless...
How to remove clutch on dyson dc07
This service is hard to explain. Try googling it so you watch a video of how it is done. You can purchase belts and rebuild the clutch with the new belts or you can purchase a new clutch with belts already installed
Mar 27, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
I need a belt for a kenmore vacuum cleaner model # 721.36078601
seras parts direct has the belt. some of the sears store where you purchase the new vac, they have the belts on the shelf. might be a 5275 belt.
Feb 24, 2010 | Vacuums
The belt needs replacing
Here is the manual to your Hoover U6630
www.thinkvacuums.com/pdf/uprights/Hoover_U6630.pdf
it goes into detail on how to change the belt and which belt to purchase. Ask for a flat belt Hoover part No. 38528035 when you're going to purchase the replacement belt
Aug 31, 2009 | Hoover U6630-900 WindTunnel Bagless...
Windtunnel belt
I've successfully used a compatible belt - Royal 104425001 .It's still new, but for the time being at least - it works.
Jul 29, 2009 | Hoover S3765-040 WindTunnel Bagless...
Eureka Boss Model 4703 Type Belt Problem
Belt can be purchased from amazon, click here and take a look: Amazon com eureka boss vacuum belt. I hope this was helpful. Cheers
Apr 11, 2009 | Vacuums
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
Vacuums Logo
71 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
