What does it mean when F4 then F6, then F4 then F6 etc. error codes are flashing.
2 Suggested Answers
jonsnell4
  • 24419 Answers
SOURCE: Whirpool dishwasher: What does it mean when F4 then F6, then F4 then F6 etc. error codes are flashing? Any assistance will be appreciated.
F4 means it is not draining and F6 means no water is coming in.
Clear any blockage.
Posted on May 09, 2017
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
F6 error code first time star unit show f6 code
good day I have a problem with my aircon its ECOAIRE aircondition with error F6
Sep 09, 2014 | Electrolux Heating & Cooling
Whirlpool dishwasher error code f6e4
F6 error fault code...
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),water hose kinked or blocked, the dishwasher water soleniod valve defective.
Dec 18, 2013 | Dishwashers
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Oct 25, 2011 | Ovens
My general electric stove oven does not turn on.. code come out f7 and 5 6..what does t mean
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe.
Nov 06, 2010 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
