Where is my dvd order LION? - Computers & Internet
  • Computers & ... Master
  • 2,191 Answers
Contact the seller to find out as this is not a commercial site
Posted on May 07, 2017
Factory reset macbook without disk
You cannot do what you want without the original installer disc that came with the computer or a later version of OS X installer, unless the computer came originally with Lion or Mountain Lion.
Follow these instructions step by step to prepare a Mac for sale:
Step One - Back up your data:
A. If you have any Virtual PCs shut them down. They cannot be in their "fast saved" state. They must be shut down from inside Windows.
B. Clone to an external drive using using Carbon Copy Cloner.
1. Open Carbon Copy Cloner.
2. Select the Source volume from the Select a source drop down menu on the left side.
3. Select the Destination volume from the Select a destination drop down menu on the right
side.
4. Click on the Clone button. If you are prompted about creating a clone of the Recovery HD be
sure to opt for that.
Destination means a freshly erased external backup drive. Source means the internal
startup drive.
Step Two - Prepare the machine for the new buyer:
1. De-authorize the computer in iTunes! De-authorize both iTunes and Audible accounts.
2, Remove any Open Firmware passwords or Firmware passwords.
3. Turn the brightness full up and volume nearly so.
4. Turn off File Vault, if enabled.
5. Disable iCloud, if enabled: See What to do with iCloud before selling your computer.
Step Three - Install a fresh OS:
A. Snow Leopard and earlier versions of OS X
1. Insert the original OS X install CD/DVD that came with your computer.
2. Restart the computer while holding down the C key to boot from the CD/DVD.
3. Select Disk Utility from the Utilities menu; repartition and reformat the internal hard drive.
Optionally, click on the Security button and set the Zero Data option to one-pass.
4. Install OS X.
5. Upon completion DO NOT restart the computer.
6. Shutdown the computer.
B. Lion and Mountain Lion (if pre-installed on the computer at purchase*)
Note: You will need an active Internet connection. I suggest using Ethernet if possible because
it is three times faster than wireless.
1. Restart the computer while holding down the COMMAND and R keys until the Mac OS X
Utilities window appears.
2. Select Disk Utility from the Mac OS X Utilities window and click on the Continue button.
3. After DU loads select your startup volume (usually Macintosh HD) from the left side list. Click
on the Erase tab in the DU main window.
4. Set the format type to Mac OS Extended (Journaled.) Optionally, click on the Security button
5. Click on the Erase button and wait until the process has completed.
6. Quit DU and return to the Mac OS X Utilities window.
7. Select Reinstall Lion/Mountain Lion and click on the Install button.
8. Upon completion shutdown the computer.
*If your computer came with Lion or Mountain Lion pre-installed then you are entitled to transfer your license once. If you purchased Lion or Mountain Lion from the App Store then you cannot transfer your license to another party. In the case of the latter you should install the original version of OS X that came with your computer. You need to repartition the hard drive as well as reformat it; this will assure that the Recovery HD partition is removed. See Step Three above. You may verify these requirements by reviewing your OS X Software License.
Dec 31, 2013 | Computers & Internet
Hi! How to perform factory reset with a macbook air mid 2013? Is there a battery reset as well? Thanks in advance for the help!
side.
startup drive.
4. Install OS X.
Nov 04, 2013 | Apple MacBook Air
Where do I purchase os x mountain lion rebootable cd or complete disc
Lion, Mountain Lion, and Mavericks (10.7, 10.8, and 10.9 respectively) do not come on a physical CD or DVD. They are downloaded and installed through the Mac App Store.
After installing 10.7 or later, a 'hidden' partition is created on your computer that serves the same function as the physical discs did in earlier versions of OS X (10.6 and earlier), giving you access to Disk Utility, Install OS X, Get Help Online, and other functions that previously were accessed from a physical disc.
If for some reason the hard drive is damaged or the Recovery Partition is otherwise inaccessible, you can access the same utilities over the internet using Internet Recovery.
One can, however, create a bootable flash drive as a physical backup of your Recovery Partition using Recovery Disk Assistant.
All the information on how to access Recovery Partition, Internet Recovery, and Recovery Disk Assistant are available from the following articles:
OS X: About OS X Recovery
OS X Recovery Disk Assistant v1.0
Aug 12, 2013 | Apple OS X 10.8 Mountain Lion
Double side printing HP LaserJet M1120 MFP
Hi Franziska,
HP has not yet released Driver software for your MAC LION however there is a solution for this.
In order to print 2 sided ( duplex printing ) you need to install drivers and it is possible by doing Apple Update.
The link below will give you more details information of how to install the drivers.
MAC LION Driver Update
Once you have done the Update and installed the drivers, you will find the Printer name in Printers list.
Click on Printer Utility and under Layout you will find options to choose 2 sided printing
Regards,
Sean
Apr 19, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Wondering about a pattern i sent
you need to contact customer service at lion brand yarn and ask them
about your order.
Oct 25, 2012 | Lion Brand Homespun Yarn
Put and play Blu-ray/DVD movies for new iPad with Full HD quality Summary: Most Mac users have difficulty to stream Blu-ray and DVD movies to iPad 3. Today, this article will recommend a professional...
I recommend that you will post your question under the correct category and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
Aug 15, 2012 | Camping, Backpacking & Hiking
Why doesn't the lion king dvd work on my dvd player
Idk but im having same issue my guess is manufactured wrong or store has bad batch but works perfect on pc...
Nov 24, 2011 | Disney Televison & Video
Chronicles of Narnia. Lion,witch,wardrobe blu-ray won't play
Updated firmware last night (for the Bd370) and the main movie disc for Chronicles of Narnia: Lion,witch,wardrobe worked (after previously stalling). However, the bonus disc still doesn't work when I play it (just a blank screen). I traded the Blue-ray DVD from where I bought it for another one, and it made no difference. However, both Narnia discs played okay in the store on a Sharp blue-ray DVD/Tv combo.
Nov 02, 2009 | LG BD370 BLU RAY PLAYER
Computers & Internet Logo
David Payne
David Payne
