Question about Electrical Supplies
I have an etq 950 generator with no spark at the plug
  • 44 Answers
SOURCE: I have a etq 1200
check to make sure no rust around magneto
Posted on Sep 09, 2010
marilynda581
SOURCE: I HAVE A ETQ 1200 GENERATOR I NEED ON THE
I found that the switch wires under the gas tanks are pretty loose in their plugs going to the magneta.. Check all of your wireing under the gas tank for connection..I just put mine the shop and they told me that would run on ether but not on gas.. johndogfuzz@gmail.com
Posted on Jul 09, 2012
  • 25 Answers
SOURCE: need owners manual for tg 3000 model etq 200 generator
u need a new sparkplug & the set gap
Posted on Apr 04, 2013
bfroy61834
  • 12 Answers
SOURCE: WHERE CAN i GET THE SPRING FOR THE PULL START ON ETQ 3000 GENERATOR
I assume it has a flat wound spring ? if so and it broke at the end close to the center where often it hooks in with two slots cut into the spring to fit the attaching slot. If your a bit mechanically inclined you can remake the end of the broken spring and re-install it. If it attaches by a circular bend like a closed or partially open hook it can still be rebuilt but you would need to be familiar with the use of heating torches and metal hardening. Beyond that I would be surprised if it wasn't available at the Honda dealer.
Hope this helps
BR
Posted on May 30, 2014
jklhbwer
SOURCE: Regards to ETQ TG1200 Generator Generator
parts can be found at amazon. click here and take a look: Amazon com ETQ TG1200 parts. I hope this was helpful. Cheers
Posted on Dec 15, 2014
Where can I find a service center in Pasadena, TX or Houston, TX????
YOU CAN FIND OUT ON THE YP (YELLOW PAGES) LOCALLY AND ON THE INTERNET YP.COM
Jun 17, 2015 | Northstar ETQ DG6LE Portable Generator...
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
I have an ETQ 4000. New carb, new plug. Will only start with starter fluid then die.
You know you have ignition. It isn't getting correct fuel. CHeck fuel to carb. If confirmed fuel to carb, carb is not adjusted properly.
Jan 08, 2015 | ETQ 4000 Watt Generator
Further to my question about a weak spark on my etq 1200 ,would one of these be the problem, magneto,igniter ir capacitor?
A lot small ignition spark appears to be weak when they are not.
A couple things to check. make sure your spark arrestor is clean and your ignition timing is correct; otherwords, that the flywheel key is not sheared.
Nov 25, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
Where is the muffler and exhaust on ETQ prtable generator?
The exhaust will be located on the output side of the cylinder manifold.
Sep 01, 2014 | Eastern Tools & Equipment ETQ Tg72k12 8250...
Need Owners Manual for an ETQ 1800 w inverter/Generator
Northern tools has it here, even though it's a discontinued product:
http://www.northerntool.com/images/downloads/manuals/166520.pdf
Apr 11, 2013 | ETQ IN1800i Generator Digital Inverter...
The pdf for this generator is available at easterntools.com
Feb 07, 2010 | Eastern Tools And Equipment 1200 Watt...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
