Question about Tablets & eReaders
I have a 8 inch can i reset it if it wont turn on
My tablet wont turn on I tired lots of ways to try in reset it I even try the reset button in the back plz help me I only had it for like a month
This same problem has happened to me too. My rca 10.1 inch tablet wont turn on any more and I had it for one month too. I tried the reset button and it doesn't work.
Jan 16, 2015 | Tablets & eReaders
How can i switch on back my lenova k1 android tablet that wont turn on?
Hello Ruth
If you tried the reset and it didnt work then most likely it wont come back to working again. Does it give any sign that it trys to power on?
Chadman
Nov 22, 2014 | Lenovo IdeaPad K1 10.1 inch Tablet NVIDIA...
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
RCA 7 inch table says no command
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 03, 2014 | RCA 7 DUAL TABLET DVD SYSTEM
My Freelander PD90 tablet wont turn on
Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Nov 17, 2013 | Umi FreeLander PD90 10.1 Inch IPS Screen...
MY touch screen wont work for some reason so now it wont work
I suggest you to perform a hard reset as sometimes this may be due to a software glitches chances are rare though but still you can give it try. Else you need to replace the touch panel of your table which I suggest you should not do on your own rather take it to a hardware shop. Hard reset in most of the android tablets is usually performed by turning off the tab and pressing power button while holding the volume down key.
Sep 26, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Kurio wont turn on and gets hot
read my other solutions. you have to reset or root the device true the micro SD input. really easy
Dec 27, 2012 | Techno Source Kurio Kids Tablet With...
Tablets & eReaders Logo
49 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
