Question about Miscellaneous
Manuals Onkyo M-282 user
Find
3 Suggested Answers
  • 6 Answers
SOURCE: how can I connect onkyo
your receiver must have a pre amp out on the back.
Posted on Aug 20, 2010
dunnbiker
  • 8546 Answers
SOURCE: What are the correct connections to connect a
Depends what you're trying to do with two amplifiers. Fill in the intent piece.
Posted on Apr 14, 2011
I've got an Onkyo M-282 with one channel that just died. Upon visual exam, there seems to be absolutely nothing wrong with it (the caps are all flat, not puffing, no broken components or smells...).
Likely you blew your outputs Transistors or mos fets, you cannot be sure without ohm meter. usually when one side goes out the protection kick in on both chanels
Tony
Nov 21, 2013 | Onkyo M-282 2-Channel Amplifier
How do you program the stations into memory for a tx-sv717pro?
If you dont have a manual, go to the Onkyo site
They have them there for download
Jun 27, 2010 | Onkyo M-282 2-Channel Amplifier
Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
May 24, 2010 | Onkyo M-282 2-Channel Amplifier
7.1 preamp output
called onkyo and kenwood they explained in detail how to hook up.
Jan 06, 2010 | Onkyo M-282 2-Channel Amplifier
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Connecting an onkyo m282 to a vintage (1994)onkyo tx905 receiver
I have found the solution.
Using an Audioplex SPKCNV Speaker Level To Line Level Converter should resolve the connection issue.
Jun 19, 2009 | Onkyo M-282 2-Channel Amplifier
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
ONKYO TX-SV717PRO Amplifiier
disconnect power and try after 20min without speakers.
Aug 19, 2007 | Onkyo M-282 2-Channel Amplifier
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
