Question about The Computers & Internet
My laptop has gone to sleep mode, the display is not coming.
4 Suggested Answers
sardanadixit
  • 813 Answers
SOURCE: my laptop seems to have gone into sleep mode, and
Plug the charger into your laptop and then keep the power button pressed until it completely shuts down. Then press the power button again to turn i t back on.
Posted on Mar 29, 2009
  • 1170 Answers
SOURCE: LAPTOP WILL NOT COME OUT OF 'SLEEP' MODE
Turn it on, then wait, u will hear the computer turning itself on and off, but nothing is showing on the screen. so make it turn on and off, 3 time.( such as hearing the computer turned off, so that one,THEN IT TURNS ITSELF ON AGAIN, next time it turns off, that count as 2, and so on). on the third shut off then u press and hold the off button, to force it to shut down, then wait. about 5-10min., or less then 5. after then u turn the computer on.it should be on by now. if not try it again. if it happens again try one more time, if it happens again. then there something really wrong with your computer.
Posted on Jun 15, 2009
SOURCE: Wireless disconnect in sleep mode?
I think that is normal to conserve energy. There are times when it will take the network connections down to conserve energy.
If it is a problem you can always increase the time on the sleep mode or set it to NEVER.
Posted on May 13, 2012
Why won't my power options work correctly?
Don't use sleep mode, either switch off or use hibernate if you don't use the default settings.
Dec 20, 2015 | Computers & Internet
I cant enter sleep mode on my acer aspire one zg5. How do i fix?
Your settings in power mode have changed. Open up display and go to the screen saver tab (win 7) you will see the power savings option at the bottom. Go into that and change what the buttons do. You will have 3 situations to change. What happens when i close the lid, power button and sleep mode. Chances are you gave everything set to do nothing
Nov 22, 2015 | Acer Computers & Internet
Toshiba Satellite L300D. Laptop will come out of sleep or hibernate mode without prompting and display the login box.
If the login box is displayed when it wakes up, that is usual. It uses a sensor to detect when the lid id open and will come out of standby when it thinks the lid is open.
Re configure the power off settings to avoid standby or sleep mode when the lid is closed.
Feb 16, 2014 | Toshiba Satellite L300D-ST3501 Notebook
Tab does not come on after going to sleep mode
change your settings or your alarm time
Dec 07, 2013 | Cell Phones
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
Will not display
For clarification, may I know how long that your computer before it going to sleep mode?
You can change the settings on how the computer hibernate or gone to sleep mode by going to display properties >> click on the screen saver tab >> clcik on the Power button. There you can set the time on how long the computer will gone to sleep.
Let me know for any clarification.
Jul 08, 2010 | Dell E173FP 17" LCD Monitor
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
Screen distortion when coming back from idle/sleep mode
This could be an issue with your Video drivers. I would try and Download the newest drivers for my system and see if that helps the problem
Apr 22, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
