Question about ZTE Cell Phones
My volume up button on zte z958 "maven 2" does not work. its like it is broke. i push it and it doesnt even push in or pop back up. how do i fix it?
BMW Rider
  • 232 Answers
SOURCE: konka tv
Hi, go into your menu and turn off closed captioning, it may be marked "cc" or spelled out as "captioning" but either way just turn it "off" and end of problem, Happy Holidays, BMW Rider
Posted on Dec 07, 2007
  • 26 Answers
SOURCE: remote, menu button, volume up buttons dont work anymore
You need to open the remote unit and clean the touch pad contacts and the circuit board contact points with pure isopropyl alcohol.
Grease may have worked itself into the remote an has caused those button contacts not to produce the data signals.
Posted on Nov 17, 2008
  • 22 Answers
SOURCE: window doesnt raise when pushing button off track
Regulator --common on GM ---sometimes spread to all the windows over time --albeit no warning
---honk honk honk come out window gone attempted break in NO ---the window dropped in the
middle of the night ---Silly ---laugh you bought GM --Ford's No Better
Posted on Apr 07, 2009
  • 51 Answers
SOURCE: Volume pop up in the middle of my screen
Sounds like one of the front panel buttons is stuck in - possibly the volume down button. If no buttons work, this could be the reason why. Just a guess. If they all feel OK, it may still be worth pulling the back off, (Without electricuting yourself -DISCONNECT POWER!) remove the PCB board that has the buttons on it, and see if it turns on without the menu. If so, check all buttons, rare but I have seen one that looked fine but with a multimeter it showed it wasnt working. If the screen still displays the menu, Id say there is a bigger problem... HTH
Posted on Jun 15, 2009
  • 59 Answers
SOURCE: 880 universal remote volume button broke. little
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Posted on Jun 20, 2009
Where is the camera button on zte maven 3 I need to take a pic of my qr code.
Take a Picture or Video Tutorial for ZTE Maven 3 (Z835) - AT&T
https://www.att.com/devicehowto/tutorial.html#!/interactive/id/...ZTE...ZTEZ835
1. ACCESS CAMERA: Select the Camera app from the home screen. Note: This device has a 5MP rear-facing camera and a 2MP front-facing camera. The video recorder is 720p. 2. SWITCH BETWEEN FRONT/REAR CAMERA MODES: Select the Switch camera icon. 3. TAKE A PICTURE: Select the Capture icon. To focus ...
Camera & Video Settings Tutorial for ZTE Maven 3 (Z835) - AT&T
https://www.att.com/devicehowto/tutorial.html#!/interactive/id/...ZTE...ZTEZ835 Note: If this is the first time you are accessing the camera, swipe through the tutorial and select the camera icon to start. See the Take a Picture or Video tutorial to learn how to use the device's camera. 2. CHANGE PICTURE SIZE: From the settings screen, select Resolution then select the desired resolution. 3.
camera button on zte maven 3 Google Search
Dec 31, 2017 | ZTE Cell Phones
How to remove the pattern lock from my zte z958 android device
hi Jordan.
there is youtube videos at this link showing how to do it.
just pick the one you think will help you out.
How to remove the pattern lock from my zte z958 android device Google...
Nov 28, 2017 | ZTE Cell Phones
Why doesn't my phone turn on all the way?
Sometimes phones do this after 6 months to 2 years of use, especially the cheaper ones.
First: Remove the battery out the back of your phone for 10 seconds and then put it back in. Now try to turn it on.
Second option: This will remove all personal data from your phone: contacts, photos, apps... If first option doesn't work, then you may need to factory reset your phone. This can be done by holding the power button and volume down button while the phone is powered off. Keep pressing those buttons until you get to a screen you have not seen before. Now used the volume down control to go down the list of options and press volume up once you have "Factory Reset" selected.
If the second option doesn't work then your phone is defective and nothing short of hacking your phone will fix this. Usually it is best to invest in another phone.
Feb 12, 2016 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
My zte maven won't turn on or charge
If your chargers a loose in the phone, that a part in your charging port broke off and it is cheaper to buy another Maven.
Make sure it is not your charger by using other ones to charge.
Remove the battery and plug the charger in, if your phone works without the battery then you need a new battery
Take the battery out for 10 seconds and put it back in, now try charging it.
If non of these options work for you, then your phone is most likely defective and it would be best to look into another phone. The good news is that if you get another Go-Phone or any other AT&T phone, all you need to do is take your sim card out and put it into the new phone to activate it. This means the phone will work right away and you will be able to keep your remaining air time and phone number.
Feb 02, 2016 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
Need an unlock code for my zte zmax2
Unlock by:
www.theunlockingcompany.com/index.php/zte.html
    1)Choose your phone
    2)Enter details & checkout
    3)Receive code through email
    4)Unlock your phone "The #1 ZTE Unlocking Company Online in the World"
    With over 7 years experience and 3 million phones unlocked to date. The unlocking company has established itself as the most trusted and visited website on the planet for all your ZTE unlocking needs. 1,2,3,4. Four easy steps
    Best price guarantee
    100% price guarantee
    24/7 live support OR
    How do I unlock my ZTE ZMAX 2?
    Unlocking a ZTE ZMAX 2 phone is a quite simple process.
    Please follow these steps:
The 1 ZTE Unlocking https://unlocklocks.com/blog/how-to-unlock-att-zte-zmaz-2-z958-by-unlock-code
Nov 19, 2015 | ZTE Cell Phones
Need an unlock code for zte zmax2
    Unlock by:
      1)Choose your phone
Cell Phones Logo
35 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
